Old 12-26-2021, 09:15 PM   #61
J518
Liked 151 Times in 37 Posts
Default Re: 79 Malibu- Stocker-Stick Shift
Now for the malibu....
We have made slight progress with a new driveshaft loop and driveshaft.
We have completed the brakes and they are bled, working well. Next, was the interior where we have completed the carpet, seat mounting, and seat belts. The switch panel is just sitting in there and not the final destination.
Lastly, We have finally received our block back and now can start assembling!!!
J518 is offline   Reply With Quote
Old 12-27-2021, 12:10 PM   #62
Nick Heath
Liked 576 Times in 137 Posts
Love this build! Those boxy Malibus are one of my favorite body styles - they make great-looking race cars - and the clutch pedal always adds several points to the cool-meter.
Can't wait to see this one on the track!
Old 01-15-2022, 09:21 PM   #63
doglover44
doglover44's Avatar
Liked 496 Times in 234 Posts
Hows it coming along ?
Jake Biermann
Old 01-23-2022, 08:52 PM   #64
J518
Little by Little
Fuel line, pump, regulator mounted. Whats everyone use for a quick "tap" for fuel checks?
Old 01-23-2022, 08:55 PM   #65
J518
Something we've been scratching our head on is the clutch linkage and finding the right headers. We end up just buying a set and rerouting the #5 hole to give us clearance. Here is the before pics.
Old 01-23-2022, 08:57 PM   #66
J518
And the after...
Old 01-23-2022, 09:03 PM   #67
J518
Update on the rest.
We did get our crank balanced. We also bought a set of Total Seal rings $$$$
Intake acid dipped and painted.
Waiting for bearings to start assembling.
We cleaned up and painted the instrument cluster and bezel around it.
Settled on the switch panel location so we started wiring. So far I am really happy with how the wiring is going and the routing to the glove box.
Tach mounted.
Fuel pressure gauge mounted.
Clutch and flywheel arrived.
Should really see some movement now if we can start assembling the short block!
Old 01-23-2022, 10:06 PM   #68
Rory McNeil
Liked 1,112 Times in 304 Posts
Maybe I am just used to the old Holley fuel pressure regulators, but that appears to be plumbed wrong. On my Holley reg, the higher pressure feed goes to the bottom, where you gauge is plumbed, and the side ports are reduced by the adjusting screw. Seems odd that you couldn`t find headers to work with the factory clutch linkage, as I have seen several stick G body GMs with a 4 speed and headers, but at least you could make those work.
NHRA 6390 STK
M/S 85 Mustang
Old 01-24-2022, 10:11 AM   #69
mham72
Liked 7 Times in 4 Posts
Must retain the unaltered stock manifold, consistent with year
and engine horsepower claimed. Grinding, sandblasting, or any
other modification
inside manifold prohibited. Runners and plenum must retain
OEM appearance.
mham72 is offline   Reply With Quote
Old 01-24-2022, 03:01 PM   #70
J518
other modification
OEM appearance.
Of course! Just the best way to clean out the rust.....
