#61 |
Liked 151 Times in 37 Posts
Now for the malibu....
We have made slight progress with a new driveshaft loop and driveshaft. ![]() We have completed the brakes and they are bled, working well. Next, was the interior where we have completed the carpet, seat mounting, and seat belts. The switch panel is just sitting in there and not the final destination. ![]() Lastly, We have finally received our block back and now can start assembling!!! ![]() |
#62 |
Liked 576 Times in 137 Posts
Love this build! Those boxy Malibus are one of my favorite body styles - they make great-looking race cars - and the clutch pedal always adds several points to the cool-meter.
Can't wait to see this one on the track! |
#63 |
Liked 497 Times in 234 Posts
Hows it coming along ?
Jake Biermann |
#64 |
Little by Little
Fuel line, pump, regulator mounted. Whats everyone use for a quick "tap" for fuel checks? ![]() ![]() |
#65 |
Something we've been scratching our head on is the clutch linkage and finding the right headers. We end up just buying a set and rerouting the #5 hole to give us clearance. Here is the before pics.
#66 |
And the after...
#67 |
Update on the rest.
We did get our crank balanced. We also bought a set of Total Seal rings $$$$ Intake acid dipped and painted. Waiting for bearings to start assembling. We cleaned up and painted the instrument cluster and bezel around it. Settled on the switch panel location so we started wiring. So far I am really happy with how the wiring is going and the routing to the glove box. Tach mounted. Fuel pressure gauge mounted. Clutch and flywheel arrived. Should really see some movement now if we can start assembling the short block! ![]() |
#68 |
Maybe I am just used to the old Holley fuel pressure regulators, but that appears to be plumbed wrong. On my Holley reg, the higher pressure feed goes to the bottom, where you gauge is plumbed, and the side ports are reduced by the adjusting screw. Seems odd that you couldn`t find headers to work with the factory clutch linkage, as I have seen several stick G body GMs with a 4 speed and headers, but at least you could make those work.
#69 |
Liked 7 Times in 4 Posts
Must retain the unaltered stock manifold, consistent with year
and engine horsepower claimed. Grinding, sandblasting, or any other modification inside manifold prohibited. Runners and plenum must retain OEM appearance. ![]() |
#70 |
Of course! Just the best way to clean out the rust.....
