Old 02-27-2022, 04:33 PM   #1
Bob F
Liked 16 Times in 11 Posts
Default Bracket fox body build,
Looking for some suspension help and keeping the factory 4 link suspension.
Car bottoms out when leaving springs are 200in# factory stuff stock type shock.
Should we be looking for stiffer springs or just a stiffer shock.
Bob F is offline   Reply With Quote
Old 02-28-2022, 03:24 PM   #2
Doug Hoven
Liked 869 Times in 165 Posts
Default Re: Bracket fox body build,
With this answer I'm assuming this car won't be used for street driving. I personally have an 83 mustang that I daily drive, but also race from time to time. For one run I mounted a gopro to watch the rear suspension on a run, and WOW was it a mess(bear in mind this is a stick car). Crazy pinion angle, some wheel hop, and a whole lot of typical fox body squat. The only modifications so far is a set of aftermarket lower control arms. In your case, I would definitely get a good set of rear shocks for the car, but would also take a good look at getting some stiffer springs for the rear. I've also heard a lot of people used to run air bags in the rear, but that may be just to maintain some streetability.
1189 F/SA
Defunzalo Racing Enterprises
Old 02-28-2022, 04:31 PM   #3
Bob F
Drives it to the track and some cruise nights at the most.
Old 02-28-2022, 09:39 PM   #4
Shadylane
Shadylane's Avatar
Liked 173 Times in 52 Posts
I have used this setup with success. Anti-squat suspension. They have several different types including street strip. I think it’s priced reasonably.
https://www.baselinesuspensions.com/...tegory&path=59
Kelly Lane Stk4991
Shadylane is offline   Reply With Quote
Old 03-04-2022, 08:28 PM   #5
fordteacherguy
Liked 160 Times in 51 Posts
Single drag bag in the RR will work wonders....
Brian Thompson
NHRA Stock / Super Stock
Class P/SA 6665 SS/MA 6665
fordteacherguy is offline   Reply With Quote
Old 03-04-2022, 09:08 PM   #6
Wayne Scraba
Liked 186 Times in 48 Posts
An ARB of some sort will be your friend….(properly set up and adjusted)…
Wayne Scraba is offline   Reply With Quote
Old 03-05-2022, 04:00 PM   #7
fordteacherguy
All suggestions put out good...what's your price range? $42 Drag Bag $300-500 Baseline Suspension set up (BTW very nice stuff , I run the Outlaw on my SS'er but still doesn't address body roll but fixes IC problems and stock suspension flex issues, $ 260 plus Install for rear ARB (I run a UPR with roller bearings.
A bag will fix most body roll issues but not the rest... FYI I stiffen up RR shock 2 clicks with a bag to compensate for additional spring rate.. Works for me.... your mileage may vary!
Good luck!
Brian Thompson
Old 03-05-2022, 06:24 PM   #8
Bob F
If I can talk the owner into it I’d like to dial in some anti squat and use the Viking coil overs he purchased.
The car ran a 10.81 @131. W/a 1.88 60’
