Old 07-05-2022, 10:18 PM   #181
Todd Geisler
Liked 345 Times in 149 Posts
Default Re: 8.50 index build
Headers all bolted up.
As much as I procrastinated on building the headers, I am pretty happy with how they turned out. Just don't wanna do another set any time soon. lol
Todd Geisler is offline   Reply With Quote
Old 07-05-2022, 10:24 PM   #182
Todd Geisler
Oxygen sensors and bungs installed.
Throttle rod needed some tweaking to clear the fuel rail. Just a small offset is all that was needed.
Took some time to get the front brakes/calipers shimmed up and then packed the wheel bearings with grease to finish that up.
Old 07-05-2022, 10:32 PM   #183
Todd Geisler
Time to get back on the wiring.
Starting on the coil harness.
This was the second attempt at the coil harness. The first one I stopped when I realized I chose too large of gauge wire which just wasn't going to work. This second attempt I did the splices just past the merge point Just under the tube at the firewall I had two Deutsch connectors at the firewall so space was limited to try and stagger the splices. The lump really bugged me so I had to come up with another plan to clean up the look...
Old 07-05-2022, 10:35 PM   #184
Todd Geisler
Took a break to wire up the steering wheel.
Just need to install the Raychem shrink boot on the Deutsch connector.
Old 07-05-2022, 10:40 PM   #185
Todd Geisler
For the coil harness I decided to install a Mil Spec connector on each side to pass the wires through the firewall. This allowed me to run all the coil wires through the firewall and do the needed splices inside where I had more room to stagger them and where they would be more hidden behind the dash.
Old 07-05-2022, 10:45 PM   #186
Todd Geisler
One other small wiring project completed was the engine grounds. I needed to connect several large gauge cables to the back of the passenger cylinder head, but there was only 1" of clearance and near impossible to get s bolt started, so after some searching I found a stud that worked.
Old 07-05-2022, 10:47 PM   #187
Todd Geisler
One final detail recently was to sand the powder coating off the chassis tag and polish it up.
Old 07-06-2022, 03:44 PM   #188
jims5600
Liked 21 Times in 9 Posts
Todd,as you usually do,the workmanship is superb. It is a pleasure
watching your build. Thanks for taking the time to keep us posted on
your progress.
Jimmy
jims5600 is offline   Reply With Quote
Old 07-06-2022, 04:12 PM   #189
Todd Geisler
your progress.
Jimmy
Thanks Jimmy.
I just hope people enjoy following along and can get an understanding of what it takes for a build like this start to finish.
Old 07-07-2022, 10:23 AM   #190
davidhuff
Liked 120 Times in 42 Posts
Work Of Art!
Thanks for taking your time to post all those great pictures of your build.
