Old 07-07-2022, 12:40 PM   #191
Todd Geisler
Liked 345 Times in 149 Posts
Default Re: 8.50 index build
Originally Posted by davidhuff View Post
Work Of Art!
Thanks for taking your time to post all those great pictures of your build.
Thank you. Lots more to come as there is plenty more work yet to be done.
Todd Geisler is offline   Reply With Quote
Old 07-24-2022, 09:39 PM   #192
Todd Geisler
With the coil harnesses done it was time to move on to the engine harness. So first up was to work on the harness from the ECU to the firewall mil-spec connector. Once the wires were run, I metered the wires end to end to verify the pin outs on both ends.
Old 07-24-2022, 09:43 PM   #193
Todd Geisler
With the sub harness done it was now time for the engine harness.
Old 07-24-2022, 09:47 PM   #194
Todd Geisler
While working on the engine harness I wanted to power the system for the first time to verify the display was operational.
The inputs from inside the car were tied into the ecu via a MAD Racing distribution block.
Old 07-24-2022, 09:50 PM   #195
Todd Geisler
Back to finishing up the engine harness...
Old 07-24-2022, 09:59 PM   #196
Todd Geisler
With the wiring pretty much done, it was time to install the transmission and converter. I had concerns over the converter pilot length given this car has an additional 1/8" block plate along with the 1/4" midplate. And sure enough, the pilot is too short as are the block bellhousing dowels. So while the trans was still in the car I wanted to weigh the car before removing it to resolve the two trans issues.
Weight as it sat on the scales, no driver.
I also weighed and accounted for all the parts not bolted to the car yet.
and a quick weigh with driver...
So in the end the car should be right at 2640 lbs with driver, race ready.
Old 07-26-2022, 01:24 PM   #197
sst7250
sst7250's Avatar
Liked 45 Times in 32 Posts
Killer build as usual....
sst7250 is offline   Reply With Quote
Old 08-03-2022, 07:40 AM   #198
Carroll Morris
Liked 5 Times in 3 Posts
Awsome looking car as usual. Looking foward to see it.
Carroll Morris is offline   Reply With Quote
Old 08-03-2022, 07:46 AM   #199
Todd Geisler
Hey Carroll,
Hope your doing well!
Old 08-03-2022, 07:48 AM   #200
TOSTO RACING
TOSTO RACING's Avatar
Liked 662 Times in 187 Posts
Todd you win out of all these builds lol, again what an amazing job !! Beautiful!! The attention to detail is second to none and I thought I was anal lol.
5664 GHI/SA
1985 CAMARO RED H/SA
1985 CAMARO BLUE I/SA
TOSTO RACING is online now   Reply With Quote
