Old 08-08-2022, 10:42 AM   #631
Liked 10,756 Times in 2,236 Posts
Default Re: Dumbo The Flying Elephant
The wiring wizard, Bob Toy, will be here today to see about installing my Racepak. Some times it's best to have a pro do the work.
Old 08-10-2022, 07:06 AM   #632
A little delay had to rethink my bearing clearance. The crank is in, rear seal installed, roller cam bearings lubricated. I building this one on a bench without using an engine stand. I’m going to use a ladder to see where to degree the cam in, all of my benches are tall.
Old 08-10-2022, 09:03 AM   #633
jmcarter
jmcarter's Avatar
Liked 3,192 Times in 975 Posts
Building it the Glidden way, Mad Dog is definitely the Pro Stock GOAT, all others are mere imitations. Definitely looking forward to seeing Dumbo at Indy!
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 08-10-2022, 02:18 PM   #634
I thought it might not stress the block as much and maybe everything will spin a little easier.
Old 08-11-2022, 04:28 PM   #635
Getting ready to check where the cam centerline is.
Old 08-11-2022, 07:11 PM   #636
Cam is where it’s supposed to be. I should be able to fill some more holes and stretch some bolts tomorrow.
Building this on a bench has been a little different. The more I work on it the harder it is to wrestle into the next position.
Has anyone looked up ring gap placement for the five different parts of the ring package. Several ideas to look at.
Old 08-12-2022, 11:19 AM   #637
340Cuda
Liked 804 Times in 341 Posts
Larry,
Page 2 of the Total Seal installation sheet has their recommendation for gap placement:
https://assets.website-files.com/5ec...heet2010_2.pdf
Bill
Old 08-12-2022, 09:33 PM   #638
There are other sites that have a very different placement. I thought it was interesting.
Old 08-13-2022, 05:57 AM   #639
Glenn Briglio
Glenn Briglio's Avatar
Liked 973 Times in 310 Posts
And then there is the issue of the rings turning on pistons after running.
Old 08-13-2022, 07:43 AM   #640
So that’s how the ring gaps sometimes get lined up over each other. It’s such a physics problem.
