Old 09-30-2022, 12:39 PM   #1
NHRA1926
NHRA1926's Avatar
Liked 232 Times in 69 Posts
Default MSD grid
Anyone using the MSD power grid to run Super Street? My Digital 6AL Plus has issues, so I ordered the MSD grid system and gonna try to use it to adjust timing to run 10.90. Any one out there got any experience or suggestions? I do not use a conventional throttle stop, just a manual limiter on the back of the carburetor. Trying to let the car launch hard, then pull timing out to hit the 10.90 mark.
NHRA1926 is offline   Reply With Quote
Old 09-30-2022, 07:03 PM   #2
Keith 944
Keith 944's Avatar
Default Re: MSD grid
Yep I have the grid in both cars, the dodge (sold) was a 11.50 index car ran 10.90’s flat out that’s how I did it. Just would be hard to figure out with different days, and weather conditions.
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 10-01-2022, 07:51 AM   #3
Maverick
Liked 36 Times in 26 Posts
The thing I don't like about making changes is you got to get the lap top out to make changes. Time is important between rounds.
Old 10-01-2022, 06:10 PM   #4
Keith 944
Keith 944's Avatar
This is not exactly true. In my 1150 car I had the can buss and a timing controller I could easily reach over and change the timing and or launch rpm while sitting in the burn out box
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 10-02-2022, 04:11 PM   #5
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
Using timing retard alone to slow a car is a double edged sword.
If you only need to kill 2 or 3 tenth's it will be very effective and consistent, but if you have to kill a second or so it will play hell with with the engines bottom end, without also using a throttle stop.
Long before the Grid or even timing retard boxes, I used to use a dual point distributor and cut one set of points in and out with a timer and retarding 18-20 degrees out since I had trouble making a tunnel ram work consistently with an air stop. .... It was deadly consistent ,but it was hell on both the rod bearings and the crankshaft .
Old 10-03-2022, 06:32 AM   #6
SGSST109E
Liked 126 Times in 61 Posts
A switch on the shifter to retard the timing back in the modified days.
SGSST109E is offline   Reply With Quote
Old 10-03-2022, 12:56 PM   #7
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Early 1980's trying to slow my Camaro down for S/ST I tried retarding the timing after the shift....had an MSD retard box and had them send me chips
Toggle switch on the shifter
Flat top SS piston short block.....thin wall pins
My best engine could go 10.40's...
Last TT at Etown points race.....flip switch and a couple seconds later.....BOOM.....Pin broke, piston turned sideways !
Was it a co-incidence? Thin wall pins were known to fail but retarding the timing too much was a bad idea......I believe.....
I just threw those chips out a few weeks ago !!
Rich Biebel
S/C 1479
Stock 147R
Old 10-04-2022, 12:39 AM   #8
Mike Gray
Mike Gray's Avatar
Liked 703 Times in 203 Posts
It became much easier to run Super Street & Super Gas using a good throttle stop controller. I tried the manual limiter but if your trying to kill much et it creates a bunch of problems. I finally gave in a got a Dedenbear timer and air actuator on the linkage. Much more consistent and you can use it at either end.
Mike 7570 A/SA
Old 10-05-2022, 03:14 PM   #9
Maverick
Hey, Keith, I know you can change the start rpm, but I don't think you can change the timing, you can see what the timing is, but you can't change it
Old 10-06-2022, 10:05 PM   #10
DailyDriverSst
Liked 7 Times in 6 Posts
Very doable.
Tip: Leave your timing degrees the same, just move the curve in and out.
At 5 degrees, I've observed a 10:1 ratio
IE, putting timing in at 1.8 on one run and 2.5 on the other run, slowed the car 7 hunds. 7 tenths of timing was 7 hunds of ET. But that's in a very specific application. YMMV.
DailyDriverSst is offline   Reply With Quote
