Old 04-16-2008, 11:07 PM   #1
pro70z28
Default Billet Aluminum Dash Bezel
Got the gauges picked out I think for the dash project. . I downloaded the ones I want off the net, sized em' to the specs on the site & printed the faces out on the printer. Then I cut some PVC gauge housings on the CNC. They are a little deeper than the actual gauges but that'll insure I have ample room for the real deals down the road. Now I can make a bezel. That outta' keep me busy for awhile.
Cut the bezel out on the CNC. There's a bunch of steps to get this thing cut. I keep thinkin' one BooBoo & it's scrap. :shock:
Got the bezel off the table. Now comes the task of bending it in the right places & at the correct angles to fit the dash.
Got it roughed into the dash cover. Still rough but close enough that I know it will fit. The right wing is 1/2" longer than the left wing, so angles are different. I think I got it purdy' close though. Next is to cut the contour in the fiberglass for the oversized tach & speedo.
{that's a relief}
pro70z28 is offline   Reply With Quote
Old 04-19-2008, 11:05 PM   #2
pro70z28
Default Re: Billet Aluminum Dash Bezel
Got a little further on the dash today. I made plugs out of PVC to form the gauge wells, since these gauges are too big for the original bezel opening.
I did the kitty hair "form the bezel to the dash deal" again. Used vinyl & spray Pam as a release agent.
One last big hurtle for me. TIG welding on the bezel w/o ruining it. I welded some strap aluminum to the top & bottom to stiffen up the bezel & to provide a place for rubber mounting grommets.
Got the bezel just setting in place. It's being held in by the dash bar. Close enough to see what it'll look like.
Old 04-21-2008, 11:39 AM   #3
BIZMANRACING
BIZMANRACING's Avatar
very nice work...
go into business for yourself and sale one to me. i got a 79 camaro it would look great. the cost of gauges would be preety high to. but, hell if you had to ask how much you should not be here.
S/ST 1739
Carlos Mendes
BIZMANRACING is offline   Reply With Quote
Old 04-21-2008, 12:08 PM   #4
pro70z28
If I told you how many hours I had in that thing you would laugh.....
Old 04-21-2008, 05:12 PM   #5
Keith 944
Keith 944's Avatar
man, that does look good, nice to see someone take pride in their work.
Old 04-23-2008, 10:44 PM   #6
pro70z28
Thanks Keith
Old 04-24-2008, 08:08 AM   #7
CPOlesen
That is a super job. I wish I had that talent. If I can't make it with Duct tape and J B Weld then I'mn toast.
CPOlesen is offline   Reply With Quote
Old 04-25-2008, 10:14 PM   #8
pro70z28
Thanks CPOlesen
Old 05-04-2008, 11:17 PM   #9
pro70z28
Got the bearing housing for the steering column (firewall) done this weekend. Now all I need are those back ordered steering column parts.
I got one last thing done this weekend. I pulled the old dash out & used the glove box as a plug to make this mold. Got a couple little places to touch up and then I can make up a couple fiberglass glove boxes to finish off around the intercooler. The door has that imitation leather pattern, & the Camaro logo. They came out O.K. so far.
Old 05-05-2008, 09:56 PM   #10
pro70z28
Little steering column mock-up tonight. The Mark Williams quick release hub came today.
