#51 |
Liked 10,779 Times in 2,240 Posts
That's why we run class, we love heads up runs. At least I do.
#52 |
Guest
Posts: n/a
Regarding 4 link. …I get to crew chief a 2006 Haas GTO Pro Stock car in Top Sportsman. My partner and I have done pretty well and I’ve got to say, it’s all in the 4 link, front and rear shock settings. It doesn’t hurt to have a great driver/partner either but my point is that the chassis tuning has helped my stocker too!
QUOTE=GUMP;673882]Not taken that way at all. I think that these are conversations worth having. In 2010 I got one of the first Body-In-White Camaros. At that time I tried to work with Chevrolet to put a torque arm in it. Knowing that whatever the NHRA approved would be the standard going ahead, I didn't want to rock the boat by going directly to them myself. It was my thought that the torque arm would be the least controversial option. Obviously, that did not go my way. That said, the four link is nowhere near as forgiving as a torque arm set-up. The precedent had already been set for the Corvettes to run a solid rear. So, the NHRA had to allow something. I really don't see the four link as any great advantage.[/QUOTE] |
#53 | |
Liked 2,354 Times in 554 Posts
Daren Poole-Adams NHRA Stock/SS 2007 |
#54 | |
Guest
Posts: n/a
Think I’ll ask for a Tesla in A/ Last edited by Barry Polley; 01-10-2023 at 05:34 PM. |
#55 |
Liked 1,943 Times in 584 Posts
When I compare my combo to others I check the ratio between cu in and the factored HP rating. My ratio is 0.90 HP per Cu In. Some in my same class are rated at 0.75 hp per cu in. So there is no way I can compete with that. My combo is a flat top with a q jet. Given that the 632 should have at least a 570 hp rating. Now remember that engine probably has a very high compression ratio and CNC ported heads. So it might need to be a bit higher than a 0.90 ratio.
Mike Pearson 2485 SS |
