Liked 19 Times in 12 Posts
While my dash is apart I’m thinking about installing a brake pressure gauge. Will I need to bleed the line feeding the gauge? Chances are it will sit higher in the car than the master cylinder. Feel free to post pics of your setup. Thank you. Mitch
Mitch Beri- The Motor City 1985 GT- “Stock-ish” 5.0 motor, AOD/ trans brake. 12.68 @ 101.31mph. https://www.facebook.com/groups/FOXBODYFLEAMARKET/ |
Liked 277 Times in 77 Posts
#3 | |
Liked 708 Times in 285 Posts
I bleed mine with gauge lower then master cylinder. Then mounted on A pillar rollbar. Very easy to see and get pressure right. But to be honest when running footbrake races I no longer look at gauge.
Liked 11,032 Times in 2,267 Posts
Try to use a glycerin filed gage. I believe that they are more durable.
Liked 2,794 Times in 983 Posts
Lamb Components gauge?
Liked 237 Times in 126 Posts
Bite the bullet and go electric. No fluid in the cabin.
Liked 113 Times in 41 Posts
I second the electric. There should is almost always a spare port if you're using a Hurst line loc. Or a Tee anywhere in the front brakes. Electric gauge is no mess!
