Old 03-13-2023, 09:16 AM   #781
Liked 10,706 Times in 2,229 Posts
Default Re: Dumbo The Flying Elephant
Well our team, granddaughter, lost in the finals of the Kentucky girls basketball championship. Her team was very good but the winner was better. For her and most of the team there is next year.
Now I can get back to work on Dumbo. I have to admit it was fun being in Kentucky at tournament time. It made me forget about not getting into the Gators do to not having the correct expectation date on the credit card while using a transfer.
Old 03-16-2023, 06:15 AM   #782
Pre lubed the engine in the car, what a darn mess.
Old 03-16-2023, 10:49 AM   #783
Mike Gray
Mike Gray's Avatar
Liked 685 Times in 196 Posts
LOL, I can relate. I pre lubed my FE on the engine stand a week ago, brand new Milodon pan leaked at the drain plug which was as tight as I thought it should be. Also with valve covers off once oil comes through the rocker shafts it floods the top of the motor even with restrictors and runs out down the sides of the block faster than you can clean it up.
Were you having leaks or just over flow?
Mike 7570 A/SA
Old 03-17-2023, 08:49 AM   #784
Above the oil filter on the block there are two 3/8 NPT plugged holes. Bottom one goes to the filter and crank driven oil pump and the top one is the passage the the oiling system. I use a three gallon viton seal bug spray to pressurize the system the system. The mess occurres when the hose is disconnected and the plug is installed with my left hand.
Old 03-17-2023, 03:46 PM   #785
Dyno
Dyno's Avatar
Liked 685 Times in 204 Posts
Melling makes a great oil primer. Larry, no matter on fast you are with the pipe plug, it is always a mess, especially the first time before you realize what happens.
Dyno is online now   Reply With Quote
Old 03-17-2023, 06:53 PM   #786
tommy d
tommy d's Avatar
Liked 359 Times in 135 Posts
6th
Old 03-18-2023, 09:26 AM   #787
Who owns this car, with the peace sign, mag wheels, and four on the floor?
Charlie Daniels
I spent a better part of a day looking for some body parts that I put up to keep dust off of them. I tore the car apart after Indy and just now putting it back together. Sometimes I forget where I put stuff, just another stupid old man trick. I will not get much done this weekend 'cause it March Madness! Its the best of college sports on TV.
I got a lot done today. If everything goes well we should be smelling smoke latter this week. As y'all can see I till have a lot of cleanup to do on getting the wires looking better. It's a real pain to get the valve cover off on the passenger's side just to check valve lash. Headers have to go on in an assigned order. Believe it or not I can get 10 O2's on the car and only have to install one in the pipe before installing the pipe on engine.
I took a picture of the oil filer base with the two plugs that make a mess when I fumble them. Me and the air inlet almost look eye to eye
ID:	66555   Click image for larger version
ID:	66556   Click image for larger version
ID:	66558   Click image for larger version
Old 03-21-2023, 12:45 PM   #788
MR DERBY CITY
Liked 7,937 Times in 1,518 Posts
Smile Re: Dumbo The Flying Elephant
Larry, I expect you to get many things done this week since your Favorite college BB team lost Sunday. Perhaps DUMBO will be out soon .?
Old 03-21-2023, 04:07 PM   #789
Indy Pts race end of April. Maybe in FSS/F, it makes the tires think they’re bigger.
Old 03-22-2023, 02:20 AM   #790
Dave Reuland
Liked 37 Times in 8 Posts
I’ve been studying the new engine management system from Holley. The first items I’m going to get and test is a backup for every sensor. I would feel very silly to travel 600 to 800 miles to race and have a problem with a $30 sensor.
If two identical air temp sensors vary 3 degrees would I need to change the offset to make the ECU supply the engine with identical A/F and spark of the previous run?
Now that I’ve thought about it a faulty O2 could cause all kind of headaches.
Larry don't forget the 2 coil drivers, our's went bad after 3 years and we replaced every sensor before replacing the coil drivers which fixed the hot misfire and no start problem. Main harness also developed an open which would shut the engine off at the hit.
Dave Reuland is offline   Reply With Quote
