Old 03-10-2023, 03:32 PM   #1
Woodfin
Liked 288 Times in 109 Posts
Default Ladder bars for 1975 Vette, [C-3 body]
These photos show the "trunk" floor cut out and the OE rear assembly removed, which is the beginning of the of the process.
More progress soon.
ID:	66304   Click image for larger version
Old 03-11-2023, 08:35 PM   #2
Woodfin
Default Re: Ladder bars for 1975 Vette, [C-3 body]
The "core"
Old 03-12-2023, 12:24 AM   #3
Woodfin
Moroso 28" front with Billet Specialties Street lite wheel at approximate ride height.
Moser 9" bare housing with overlength axle tubes. This allows installing the axle bearing ends in just the right place.
The tables are my trusty, high milage, old, construction tables that have endured many builds.
ID:	66372   Click image for larger version
Old 03-14-2023, 01:40 PM   #4
Woodfin
Ladder bars also require a properly setup front suspension.
Old 04-04-2023, 08:41 AM   #5
Woodfin
Smooth, easy movement, plenty of travel, minimum bump steer and the proper stance.
ID:	66657   Click image for larger version
Old 04-04-2023, 08:46 AM   #6
Woodfin
Once the rear wheel wheels arrive the rear section work will begin. I want to be sure of the framework required for the Hoosier 30 x 10.5 radial. I think a sectioning/narrowing of the frame will be sufficient. The wheels will arrive in about two weeks.
Old 04-04-2023, 08:50 AM   #7
Woodfin
The correct tire.
Old 11-05-2023, 07:36 PM   #8
Woodfin
update photos
ID:	68956   Click image for larger version
ID:	68957   Click image for larger version
ID:	68959   Click image for larger version
ID:	68960   Click image for larger version
