Go Back   CLASS RACER FORUM > Class Racer Tech > Garage Tech
Old 10-19-2023, 12:16 AM   #11
MAURICE BLENDHEIM
Liked 285 Times in 87 Posts
Default Re: wire feed welder ?
Originally Posted by rod View Post
I noticed, the other morning when welding, in areas when it is hard to get the nozzle just right, there was more splatter. and in an area, where 'everything was perfect' way less. and that was one why I asked. inside angle iron corners seem to be bad. guess it because of nozzle position.
not to cause hard feelings, but...have you ever looked at harbor freight flux wire and then looked at forney. exactly the same. except HF is way cheaper. just sayin'.
thanks Rod in AZ
Rod… Try welding out of a corner instead of into it. MB
MAURICE BLENDHEIM is offline   Reply With Quote
