Liked 904 Times in 237 Posts
I have a 1997 Gold rush Trailer and I am in the process of buying a new crew cab dually and does anyone have experience or a simple solution to use the Jaws welded on the trailer to use with a pin on the new truck Bed ??
Don Kennedy 7701 SS Last edited by Don Kennedy; 10-23-2023 at 06:40 PM. |
Liked 10,926 Times in 2,257 Posts
Try Trailer World in BG Ky.
Thanks Larry I found a King Pin adapter for trailers with inverted 5th wheel hitches I think it will work on my new Dually with the towing package hole in the bed,
Don Kennedy 7701 SS |
This is my issue now I need a simple King Pin that will fit in my new truck Puck OEM system I do not want to cut off my Gold rush jaws on my trailer < I do not want to add a new system to the bed all i want is a simple way that a king Pin that will fit in the oem puck system on my new crew cab dually if any one has a solution or can make me a king pin witha plate on it that will fit down into the puck system give me a call 602 284 6240
Liked 93 Times in 52 Posts
Have you reached out to B&W, yet? I dont even think they make the square bed adapter to inverted kingpin anymore. If I buy a newer truck, I will likely have to convert my GR inverted to a gooseneck ball.
Clark |
I could not find a answer so I am going to convert my Gold Rush to a goose neck
Don Kennedy 7701 SS Last edited by Don Kennedy; 10-27-2023 at 11:17 PM. |
