I have an 70 nova bracket car, looks like it was built around the 90s or so. The car is on 33x10.5 Hoosier slicks, 5:13s in the rear. I’m hitting trap around 63-6500. How would going down to 29s affect my car? Car is running around 7.4-7.5.
Car specs: 12 bolt Strange axles 5.13 gears Th400 reverse manual valvebody no brake 60 over 350 Dome top pistons H beam rods Solid lift cam Holley alum heads Quick fuel 750 Last edited by Meaney124; 12-03-2023 at 09:27 PM. |
Liked 759 Times in 379 Posts
1/8th mile?
cam specs? converter size, flash rpm and fall back rpm stock suspension? footbrake? Last edited by 1320racer; 12-04-2023 at 07:48 AM. |
@1320racer 1/8th mile unsure of cam specs haven’t torn apart to get numbers or anything, ladder bar, and footbrake is about all the info I can give you lol
Summit has a gear ratio calculator on their site. Plug in the info it should get you close
Liked 405 Times in 158 Posts
So, you must be trapping about 118mph at 6500?
33 to 29 inch tire jumps you from 6475rpm to 7367rpm. (approx) http://wallaceracing.com/calc-gear-tire-rpm-mph.php |
#7 | |
Don’t know if he mentioned it is 1/8 mile. Lol. I do believe some of these calculators have 1/8 mile data
