Old 03-25-2024, 12:47 PM   #1
triplezero
Default RPM dip going onto stop, w/ racepak graphs
Been having a problem with the RPMs dipping going onto the stop or right after going on. It seems random, doesn't seem weather related or any pattern really. Thinking of trying to tighten up front suspension not to bounce as much, and also thinking maybe making the first timer smaller and raise cruise rpm. Where would you guys start?
468bbc, 760 hp, glide, 4.10s, 30x9, 3370, T1 .400, cruise 4050, shift on rpm
Car is pretty good except this issue that'll change the 60ft .02-.04. Also notice at times, the transition from the falling rpm to the cruise at times will be a sharp "L" and sometimes slowly curls out, which will also change the 60. Don't know if its related or not.
Name:	Screenshot 2024-03-25 121937.png
ID:	69448   Click image for larger version
Name:	Screenshot 2024-03-25 121508.png
ID:	69449   Click image for larger version
Name:	Screenshot 2024-03-25 123819.png
triplezero is offline   Reply With Quote
Old 03-26-2024, 09:30 AM   #2
Pauley
Liked 287 Times in 53 Posts
Default Re: RPM dip doing onto stop, w/ racepak graphs
Whos carb and what size?
What size carb?
Electric or air stop?
Are shifting on stop or on rpm?
I dont know much but maybe i can help
ep
Pauley is offline   Reply With Quote
Old 03-26-2024, 10:11 AM   #3
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Don’t let Pauley bullshyt you, he’s a bad man running a throttle stop.
Old 03-26-2024, 01:17 PM   #4
Pauley
dont let 1290 bullchit you sir. i blind squirrel it most of the time.
by the looks of your graph i would say the you are shifting on rpm. the creep in it leads me to think rpm. most will say to try and get your graph to lay as flat as possible which you can do on time not on rpm so much. the creep has never bothered me that much as long as it repeats. but you definitely don't want the dip. that will make you pull your hair out. that is why i dont have hair. i would like to know also how fast your ride is wide open also.
ep
Old 03-26-2024, 01:22 PM   #5
Pauley
gas or alcohol?
Old 03-26-2024, 02:05 PM   #6
Pauley
Sorry for the dumb shift ? I see the shift.
ep- told you blind squirrel
Old 03-26-2024, 04:21 PM   #7
Adger Smith
Liked 880 Times in 311 Posts
Timing issue?
Timing of low gear band release and Hi gear clutches apply..
Both applied at the same time could drag RPM down.
Different servo spring or adjust the spring pressure higher.
or
More clearance in the Hi clutch pack can increase time to apply and free up drag when in low gear.
Adger Smith (Former SS)
Old 03-28-2024, 09:41 AM   #8
Phil S/ST
Liked 34 Times in 14 Posts
Not knowing the O2 readings, my guess the carb is a tick fat causing to 60ft to change. Try switching to shifting on time and try a bigger intermediate air bleed on the carb. Other fixes include raising the stop RPM, slowing stop closing speed. A smaller carb may work also. Just some thoughts
Phil S/ST is offline   Reply With Quote
Old 03-28-2024, 09:45 AM   #9
Phil S/ST
You looked good at SGMP until Webb kinda ran over everyone! Myers was too.
Old 03-28-2024, 10:34 AM   #10
Lenny5160_v2
Lenny5160_v2's Avatar
Liked 231 Times in 100 Posts
This setup is pretty similar to mine, although you have more power and are 200 lbs lighter.
Shifting on time would cost a lot of MPH. I wouldn't do that. I'd probably go up a bit on the cruise RPM to 4300 or so.
I go on the stop at .500 to get things moving. You seem to have a similar thought. Moving that timer would be a good thing to try, but I don't know which way might be helpful in this case.
Do you have a crossover hose on your carb bowl vent tubes? Maybe some fuel slosh.
Intermittent issues are always the worst.
Tony Leonard
S/ST 56
S/C 53
Lenny5160_v2 is offline   Reply With Quote
