Old 04-14-2024, 02:07 PM   #941
Liked 10,837 Times in 2,252 Posts
Default Re: Dumbo The Flying Elephant
Wow did it feel good to be working on Dumbo. After a season and a half under the hood is just very dirty and dusty. Removing the engine is a must to get clean.
Old 04-16-2024, 07:02 AM   #942
I may have found an occasional miss fire, engine coolant in the spark plug well. I think Dumbo will be quicker hitting on all 16 plugs.
Old 04-16-2024, 06:55 PM   #943
All plugs a little bit oily but not real bad. It so much easier to check valve lash with the engine out
Old 04-17-2024, 11:02 AM   #944
Rick J
Liked 73 Times in 37 Posts
I finally got the stuff made and was able to figure installed height. The kool part is I was instructed to get several different sets of valve locks. The standard, the +.050, the -.050, and the top lock. It moves the installed height around and with the help of shims I will be able to get to my coil bind target number on each spring. I’m hoping to get to size to plus .005” on installation height.
A tip of the Hat to all of the cylinder head folks, it’s not easy just to get the installed height correct, past Tech, and run hard all the way to the Finnish line. The real good cylinder head people are a bargain.
FYI, avoid +.050 locks if you can, if not use 10° locks & retainers.
Reason is locks only clamp on the valve stem below the groove, the ID of the lock is larger above the groove.
Rick J is offline   Reply With Quote
Old 04-19-2024, 10:45 AM   #945
Thanks I will check that.
Spoke with someone that had some thoughts on why the head leaked coolant in to the spark plug bore. Coolant casting core flotation. I wonder why it took two seasons of racing to appear on this head an only one season to cause a problem on the odd cylinder head. One of life’s little mysteries.
Old 04-21-2024, 08:57 PM   #946
The down side of doing it yourself, forgetting where I placed a tool because, “I don’t use it that often”. After some time I found it. Just another stupid old man trick.
Old 04-22-2024, 07:26 AM   #947
Billy Nees
Larry, look at the bright side! Soon you'll be able to hide your own Easter eggs!
Billy Nees 1188 STK, SS
Old 04-22-2024, 02:01 PM   #948
goinbroke2
Liked 404 Times in 158 Posts
Oh that's nothing, wait until you forget how to do the simplest thing...on a video for everyone to see! LOL!!
Jim Miller
103 U/SA
Old 04-23-2024, 03:55 PM   #949
Dropped the head off at Jeff Taylor Performance. Jeff said that I’m not the first to have the problem. It’s the same end on the same casting number. He made some other recommendations that should help us get a little closer in the HP race.
Old 04-26-2024, 10:17 AM   #950
Today and this weekend we haven’t any granddaughter functions to attend. I should get a lot of things re-verified and cleaned.
