I was told NHRA may now be allowing aftermarket rocker arms (Similar to Harland Sharp Non-Adj) to be used in 428 Stockers, as a replacement ? I’m not finding it in the appendage like the Molnar Rods. Brent Lykins makes a nice non adjustable shaft system I’d like to use if this is indeed correct
Liked 13 Times in 9 Posts
Roller rockers have been legal in stock eliminator for quite some time.
Liked 89 Times in 19 Posts
Detailed specifications are quickly accessible through <http://www.classracerinfo.com/>.
Chuck Norton |
Get it in writing from Pat Cvengros, or Dave Ley, but the basic intent of the roller rocker arm rule is that the rocker arm must bolt to the head without modification or machine work. I don't see where the rule specifies the method of adjustment, or that the aftermarket roller rockers must be non adjustable if the factory rockers were non adjustable. So you may not need to buy non adjustable rocker arms. I'd see what is available that I wanted, and then contact Pat and/or Dave.
Alan Roehrich 212A G/S |
#7 | |
No problem.
Liked 10,931 Times in 2,258 Posts
Don’t forget to get some really good rocker shafts. Sometimes the ends break off.
Liked 705 Times in 204 Posts
I currently have the T&D FE rockers and shafts and they work really well so far. My previous engine had POP (precision oil pump) rockers and I liked them also. If you use T&D, you need to use the street rockers because the race rockers are a paired set up with modified mounting and oil through the pushrods which is not stock on an FE.
Mike 7570 A/SA Last edited by Mike Gray; 05-02-2024 at 05:07 PM. |
