Liked 7 Times in 5 Posts
when doing the burn out car goes side ways, made 4 pass in both lane and the same every time 30 x 9 Hoosier. CO 6., new car first time out. help please . Mike
Liked 1,955 Times in 590 Posts
Rear end out of square. Broken Axle. one front brake not holding. Preload in the suspension are all things to look for.
Mike Pearson 2485 SS |
thanks. I'll check out of square and preload, every thing else is brand new.
#4 | |
Liked 759 Times in 379 Posts
Could also be the water box guy is no good or you’re pulling too far out of the water assuming you have a spool and not a posi, Last edited by 1320racer; 05-06-2024 at 01:20 PM. |
Yes spool, 9" tire stocker. thanks , I think it was the water mans first day. !
Liked 138 Times in 51 Posts
Tire guys are usually pretty good about matching pairs but it wouldn't hurt to check the circumference on both slicks.
LOCOMOTION Racing |
Liked 1,471 Times in 308 Posts
Pre-Load.
J.R. |
Liked 706 Times in 283 Posts
Square up rear end or preload
#9 | |
Liked 520 Times in 176 Posts
I had that happen to me at the second Maple Grove race in 2023, I also had a one year old Hurst Line Lock solenoid go bad me as well. I tried another line lock solenoid form a friend and that's been working OK again. "New" doesn't seem to mean anything anymore. Good doesn't also. You might be going through some New Car "Bugs", silly stuff that just needs a tweak or two and then you'll be on your way. Good luck on your adventure. You have to go race the car in order to find the problems. Have a Good Day. Respectfully, Henry Kunz 1534 H/SA |
This says all I need to know and supports what I have stated previously. Too many track owners/managers fail to understand that the water box guy(s) are the most important staff member on the track to those that are actually racing, it is not an entry level position.
