Old 04-16-2024, 04:11 PM   #21
JP1738
JP1738's Avatar
Liked 1,226 Times in 343 Posts
Default Re: TH350 Governor/Shift weights
Is there anyone coming to Reynolds this week for the D2 race at silver dollar that might have some stock or #1 weights/lighter springs I can try? I pulled my governor out to see what it had, but the kit I ordered from B&M isn't going to be here in time for me to make a change before the race this weekend, so I've already put everything back together. I wouldn't mind making a change on Thursday or Friday if someone has the parts I can borrow for the weekend. If not, it's not show stopper, I'll just wait until I get back home on Sunday and try to get it dialed in before the national event next week.
Dawson Pauley
#2827 N/SA 1980 Malibu SW 2S 305/180
#2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide
JP1738 is offline   Reply With Quote
Old 04-16-2024, 07:24 PM   #22
pmrphil
Liked 348 Times in 152 Posts
Maybe head to a local transmission shop and grab a completely stock one to try/use for parts?
Phil Molski
PMR Performance
S/C 1623
pmrphil is online now   Reply With Quote
Old 04-25-2024, 07:42 PM   #23
Eman
Liked 133 Times in 76 Posts
Working in the shop I came across some T350 governor springs. There's different weights left over from when I built some manual shift T350's using different kits. PM me an address and I'll send them to you if you want them.
Old 04-25-2024, 09:36 PM   #24
Jeff Stout
Liked 706 Times in 283 Posts
If u need lighter or heavier u can grind some off or weld a little on.
Jeff Stout is online now   Reply With Quote
Old 05-08-2024, 04:40 PM   #25
Tim H
Tim H's Avatar
Liked 482 Times in 159 Posts
JP1738 what is the latest on your adventure with TH350 weights and shifting rpm ?
Tim H is online now   Reply With Quote
Old 05-09-2024, 11:15 AM   #26
JP1738
JP1738's Avatar
I ordered the B&M shift weight kit a few weeks ago and have it sitting in my shop. I have not had time to work on changing it since then. I left it as is for the national at charlotte as it was very consistent the way it was and I didn't get the kit in until the Wednesday before I left. I'm going to work on changing it and experimenting with shift points next week. I'm taking my bracket car out this weekend to see if I can win a second consecutive 6.0 index race. Might get to change it out Sunday or whenever it finally gets dry around here again. I'll have it dialed in to the shift point I'm looking for before the next time I have it out. I'm going to try to go to the CCRA race at Rockingham in 2 weeks, should have it dialed in by then and I'll update the thread with whatever the process ends up being like.
Thanks for not forgetting about me!!!
Dawson Pauley
Old 05-17-2024, 10:26 AM   #27
JP1738
JP1738's Avatar
Got it dialed in best I can!
The car started out with a #2 weight+orange spring and stock weight+green spring, which shifted at 6750 rpm.
Then tried to make a big swing to see where that put me, left the stock weight side alone and changed the #2 weight to a #1+purple spring (heaviest spring and weight) to see how much that would change the shift point. It made a huge difference and moved the shift down to 5500 rpm.
It seems counter intuitive but a stiffer spring quickens the shift point, I decided to leave the weight alone this time and go to the lightest spring. #1 weight+red spring. That got me right where I wanted to be at 6200 on the button. In the future I may try a slightly stiffer spring, maybe one step up to bring the shift in just a touch sooner, but I think that's good for now.
Final combo for any who might reference this later:
stock weight+green spring and #1 weight+red spring got me 6200rpm.
Sorry to all my neighbors who heard me making test passes at 11pm Tuesday while testing the shifts. Can only test it at WOT...
Also shoutout to the guy who saw me testing again Thursday who yelled "DO A BURNOUT" which I promptly did. I couldn't resist.
*All testing was done in a closed environment and all safety measures were taken (helmet and seatbelts utilized)
I'll include an image of the weight and spring chart for everyone's reference and I'm going to repost this in my class racer build thread as well.
Dawson Pauley
Old 05-17-2024, 01:57 PM   #28
Tim H
Tim H's Avatar
@ junior barns post #18 seems to be pretty much bang on with your results.
Old 05-18-2024, 09:43 PM   #29
Cglrcng
Cglrcng's Avatar
Liked 364 Times in 196 Posts
Originally Posted by DanBar View Post
I tried to last night but the file format of my laptop or whatever is to large to upload to this site. The instruction don't go into much more detail other than if it shifts to early go to lighter weights and/or springs if it shifts to late go to heavier weights and or springs. The stock weights and springs on the governor will shift around 4200-4300 rpm this was a safety factor is if the unaware driver left the shift lever in 1st or low it would automatically fail safe shift before the redline of the stock engine so they didn't have loads of warranty replacement engines. Shift kits were developed to bypass this safety so you could hold any gear till you manually moved the lever . I tried weighing a few spare weighs I have from my kit to give you an idea of what they are put my 14 year old grams scale is DOA .
To resize images (jpegs, pics, etc), rught click on the closed file or pic, choose edit, if it asks what program to use, choose paint, then on the left choose resize and the largest number for pixels click on that dot and change it to 800, then hit the X upper right, choose save, then it will close (you have now resized the pic to max 800 pixels in the largest direction, retry posting that resized picture, it should now post here.
Gary Lucier - 7832 STK. / 7832 E.T. EF/S Slow Sled. I am, but a simple test of your true patience. So, do all the really "Big Wheelies" you can!
Cglrcng is offline   Reply With Quote
