Old 05-11-2024, 12:51 PM   #1
dragracerray
dragracerray's Avatar
Liked 210 Times in 91 Posts
Default What size welding cable?
I want to improve my cables. It is about 6 ft from the battery to starter solenoid and about 2 ft from the starter solenoid to the starter. I have some 4 AWG from a previous car.
Is 4 AWG big enough for this or should I go larger? What are your experiences? This is a 12 volt car.
thanks in advance! Ray
Wish I was with you guys at Cecil!
Ray Bassett
I/SA 1687, SS/DA 1687
"SuperPro is both", unknown
dragracerray is offline   Reply With Quote
Old 05-11-2024, 01:38 PM   #2
CMcAllister
Liked 920 Times in 259 Posts
Default Re: What size welding cable?
8' of 4ga, decent fine strand welding cable and not auto parts store stuff, will likely be OK. I use 2ga in most everything, rear mount, 13-16', no issues. As long as everything else is in good shape.
Old 05-11-2024, 02:24 PM   #3
Mark Ugrich
Liked 71 Times in 38 Posts
Go to windynation.com and use 1.0 gauge welding cable. They can cut to size and install cable ends for you.Ive used their cables for my build and so far i’m very happy with the quality.
Old 05-11-2024, 05:17 PM   #4
Gary Evans
Liked 16 Times in 11 Posts
1/0 welding cable or machine cable will work best
Gary Evans is online now   Reply With Quote
Old 05-11-2024, 06:21 PM   #5
CMcAllister
Only needs to be big enough to spin the starter. Once the engine is running, big cables are dead weight.
Look at what they are using on the truck or car sitting in your driveway.
