Liked 1,230 Times in 346 Posts
I've used a 3-step in my Super Street car and now my stocker since I started racing. I'm not necessarily reliant on it, but I like having it to keep me from zinging the motor in the water box. I feel confident after this many years racing I don't need one, but again, it's just there in case it tries to get away from me.
Something I've noticed over the years: I frag valve train components once a year. Every year, without fail, I will break a rocker stand, rocker arm, or push-rod. Sometimes all three depending on what gives up first. I've never had a catastrophic failure, just something that puts a cylinder down and ruins my race day. And every single time this has happened (I think 5 times now) it happened during the burnout early on in the race. Usually first or second time run of the race, it will frag something in the valve train and that's my day, over. Is the three-step causing this? I'm not exactly beating the 3-step up, honestly. It might nick it a touch while holding the line lock, but it's not hammering it the whole time. Or is it just a coincidence? If I remember correctly, it rarely frags mid-burnout on the three step, normally its just after I release the Line Lock and begin to pull out of the burnout when RPMs may climb higher than the 3-step and get close to the high side. For reference, my high-side is usually set around 7500 and my 3-step is 6500 with a converter flash of 6000.
Dawson Pauley #2827 N/SA 1980 Malibu SW 2S 305/180 #2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide |
Liked 274 Times in 143 Posts
I don't think this is the place to admit to using a three-step in a Stocker...but if you're breaking valvetrain parts in the other car...it's not from the three step. You've got some unhappy geometry or your maintenance intervals need changed.
#3 | |
As for my other car, I lash valves every oil change (40-50 runs) but rarely see much change. I might have one or two that need adjusted but typically even when I check them, they were ok anyway. I would be surprised if it was a geometry issue, Scott Duggins at PAR put it together for me and has freshened it multiple times in the last 5 years. I trust his engine building prowess. I should note that I get these rocker stud breakages despite running a stud girdle. Is a three step bad/illegal in a stocker? Or just frowned upon? Honestly don't know, I'm still new here.
Dawson Pauley #2827 N/SA 1980 Malibu SW 2S 305/180 #2827 S/ST 1978 Mazda RX7 w/ 383 sbc/glide Last edited by JP1738; 05-21-2024 at 02:32 PM. |
Liked 225 Times in 96 Posts
I don't use a burnout limiter in my dragster anymore. Never have in the door car.
Not sure if that is causing your issues, but there seems to be enough info out there about limiters not being great for valve train health.
Tony Leonard S/ST 56 S/C 53 |
That's what I'm getting at here. I like having it, but if it's gonna keep breaking stuff, I'm not sure I need it enough to justify it.
#6 | |
If you're constantly going out and banging the limiter, then yeah, it's going to break stuff. The only time I ever put my car on the limiter is on the launch. I still believe something else is going on though with the valvetrain. |
Liked 8,048 Times in 1,529 Posts
I use a limiter in the water for protection . I have never had an issue in over 30 years . On the other hand Buddy Morrison swears that they are NOT a good idea to use in the water…..I have a feeling that your limiter is wired in with the line loc …That is a VERY bad idea …. When you release the line loc button you have no protection coming out of the water …..perhaps this is when you damage your parts ????
Liked 348 Times in 152 Posts
I'd mention to Scott about breaking studs when still using a girdle - something is NOT correct. I have only seen that happen when using an incorrect (wrong) girdle for the stud spacing or, as was said, a geometry issue. Scott's a smart guy, give him a yell. Tell him I said "Hi".
Phil Molski PMR Performance S/C 1623 |
#9 | |
#10 | |
Liked 210 Times in 91 Posts
If you are talking about hitting 7500 in the burnout with a Stocker I would say you are over revving. I would question why you want to go that high in the burnout,. I have a 6000 limit in the burnout for my Stocker. It is on a toggle switch so that even when I release the LineLoc the rev limiter is still active. Finish burnout and flip toggle switch to race mode. Ray
Ray Bassett I/SA 1687, SS/DA 1687 "SuperPro is both", unknown |
