Old 09-02-2024, 08:18 PM   #1061
Frank Castros
Liked 2,753 Times in 974 Posts
Default Re: Dumbo The Flying Elephant
Larry,
Your experience and knowledge is a positive and not a weakness. You are placing too much pressure on yourself to be the top dog in FS/D despite taken the trophy the past two years. Victor wishes he was in your shoes. I agree the sixty needs work. MPH is noteworthy but ET is where the trophy is won. Dave Lebrun taught me that if you maximize the sixty foot number your ET will benefit exponentially. Test, test, test.
Old 09-02-2024, 08:54 PM   #1062
Tim H
Tim H's Avatar
Liked 484 Times in 160 Posts
Thank you to Patsy and Larry for taking time to chat with us at the BIG GO. Really enjoyed your DUMBO and the feather story. From two of your Canadian fans !
Old 09-02-2024, 10:34 PM   #1063
tommy d
tommy d's Avatar
Liked 359 Times in 135 Posts
I've really enjoyed following along these past few months. Great insight as to what is required to build a fast stocker motor. Thanks for letting us in.
Old 09-03-2024, 08:05 AM   #1064
Liked 10,895 Times in 2,255 Posts
The cartoon Dumbo move by Walt Disney around 1940 is one of my favorite childhood movies. As I get older and start to enter my second childhood it is still one my all time favorites. It?s a story about a baby elephant (a 392 and not the full size elephant 426) that could Fly.
Old 09-03-2024, 09:43 AM   #1065
MR DERBY CITY
Liked 8,194 Times in 1,536 Posts
Nice
Old 09-05-2024, 08:35 AM   #1066
Back to work. Change oil and filter, transmission, and fix an electrical issue. Run the valves and generate a thank you list. Dumbo?s success is a result from help and ideas from some really smart and knowledgeable individuals. I?m just the listener and assembler.
Old 09-05-2024, 09:42 AM   #1067
Steve Grady
Steve Grady's Avatar
Liked 137 Times in 46 Posts
Knowing how to listen and understand what is being offered is very important.
Div 3 Sales, Service and Tech for many manufacturers
Steve Grady is offline   Reply With Quote
Old 09-07-2024, 03:51 PM   #1068
Changing transmissions is not as easy as it sounds. Had to fab a cooling line. Install two different length studs for the shield and the shifter to mount to. Trim the case so the shield will fit. Drill the trans pan to fit a weld in bung. Find the proper fitting for a .187" Dia. probe to pickup trans temp. Fix the misalignment issue between the trans and the rear mount. Retie the wiring harness to keep off of headers. Clean bottom of car it's a wreck..
Old 09-08-2024, 12:24 PM   #1069
340Cuda
Liked 805 Times in 341 Posts
Larry,
Did you change to a different style or type of transmission?
Bill
Old 09-08-2024, 07:45 PM   #1070
Only a ratio change. Going to MoParty in BG this weekend.
We are very disappointed in NHRA?s response to the Factory X situation. We had plans to go to Tulsa next week now we are not so sure. It is obvious that NHRA lacks the internal resolve to enforce rules as written.
My apologies this is a build thread not a forum for policy.
