Old 09-11-2024, 01:29 AM   #141
Cglrcng
Cglrcng's Avatar
Liked 432 Times in 214 Posts
Default Re: U/SA 302 ffffford build
Hey Jim,
I will attempt to not write a whole book here, but will attempt to add a few suggestions since you have made the decision to make the tank to cell switch. Here is what I did.
Note: Our combos are very different (as mine is a 1980's pretty rudimentary EFI single point throttle body fuel injection system. Yours is not (but both our vehicle manufacturers have provided or not provided (depending on year produced), certain fuel system safety features that we may or may not be aware of when we start the process to delete and add to the "fuel system" we are allowed to convert/modify to achieve the switch to a cell.
I removed the tank and straps, fuel filler neck, and the associated in tank pump/ filter sock and upper tank vent and return line attachment and fuel filler neck and Grommet. I left the stock steel fuel lines and associated wiring alone at that point.
Then I stopped. I located (on ebay as dealers have pretty much sold off their old 1980's vehicle specific repair manual sets and they are plentiful and fairly cheap these days), a full set of vehicle specific repair manuals for my year, make, and model (including the complete chassis, trim, and wiring diagrams in a 3 book set for like $36.00 shipped). There were some surprises located in those books once I did a deep dive in that helped me make critical (as built safety items built into the existing fuel system I was not aware of prior to that date), decisions were soon made not to remove certain items or defeat their purpose in the name of safety.
I looked at the fuel system as a whole using the books as a reference and took pencil to paper then to diagram out both the as built system, and included a wiring diagram concerning the specific under dash to tank wiring and discovered a really important safety switch (a mercury activated rollover safety switch/relay), located under dash on passenger side. I then researched that particular safety feature and what it does and why (simply put key on the system pump is activated for the 3 second EFI pump prime, then turns over control to the ECM and PM.
But should the car be upended as in a rollover type accident and the key is on, and a tilt of the auto get to approx. 40 degrees of tilt or greater, the mercury rollover switch auto cuts off all power it the electric fuel pump.
At that point (I delved deep into the dash), not only located the switch, but took the time to test it to see if it still worked as designed by unbolting it from its position (hooking up a test light rig on the switch wiring output, went key on and then slowly rotated the switch to simulate an actual rollover...it worked flawlessly as built, and at about 38 degrees of tilt using a simple angle finder, key still on the mercury in the small glass bulb cutoff all power to the pump. I instantly made the decision to utilize in my second as intended design change diagram on paper the existing wiring system from battery all the way back to the removed tank location (to power my new Jegs pump and filter system), so as to not defeat that real world very important safety feature.
I looked at the real world as built system, the required NHRA minimum requirements and then on paper first re-engineered the final setup.
The new fuel cell was going into a hatchback car and required a bulkhead both top and bottom to isolate it from drivers compartment and from track/car debris, and even though the fuel cell came with an internal rollover valve on the vent line (that satisfied the NHRA rule), I went one step further and added another external rollover after the vent line exited the spare tire well.
Also pay attention to the NHRA required grounding between fuel cell and frame. In my case that it is a poly fuel cell and powder coated cell straps. And in my case I made sure to sand off an area of the strap between the poly cell (so cell makes direct grounding contact with the strap then where my grounding wire is attached between strap and frame was also a sanded area devoid of powder coating and then before filling the celI I tested the ground continuity.
It was a big deal, lots of research of rules, lots of tedious work, the work on paper before ordering anything was a key to a smooth result and a great new fuel system that in my case solved a long standing performance issue I had with the car prior...but that is a different story that is in my build thread.
Good luck on the work ahead.
Gary Lucier - 7832 STK. / 7832 E.T. EF/S Slow Sled. I am, but a simple test of your true patience. So, do all the really "Big Wheelies" you can!
Cglrcng is offline   Reply With Quote
Old 09-11-2024, 01:32 AM   #142
Cglrcng
Cglrcng's Avatar
Yes, it ended up another novel. Sry.
Old 09-12-2024, 04:44 PM   #143
goinbroke2
Liked 405 Times in 158 Posts
All good, thanks for the response! Two heads are better than one so I listen and learn from everyone. I have been avoiding the garage the last couple of days because I have so much other stuff going on. Have to put the tranny pan on and fill it..AGAIN and see if my latest "spring/valve/grinding slots/holes" recheck did anything. Not gonna lie, it's taken the wind out of my sails, so to speak. When I blew up the 3rd engine in 4 years, I parked it for 27 years. Not there yet but the "honeymoon" of having a stocker is quickly wearing off. I have another mustang (stock 86lx with 90,000km's original) that I have raced and could of bracket raced all summer, but I've been focused on the stocker and have been to the track once this year.
All that to say, I'll get back on it, but my motivation to hit the last race of the year in a couple weeks is waning.
Jim Miller
103 U/SA
Old 10-16-2024, 05:45 PM   #144
goinbroke2
Ok, time for an update. Pulled the valve body and took it to a performance tranny shop, got it back with "everything is exactly like it should be". Put it back in and still have PNN123.
So, probably pull it again and maybe send it back to Broader in Texas. Thought I done something wrong but several people have looked at it and nobody has an answer.
I was going to leave that and start pulling the gas tank but a dozen other jobs have taken priority since race season is over.
In other news...another 79 302 with the right intake and heads on it found it's way home with me for $100.
This is something else I do...off road youtube channel. This is us wheeling at my cousins in NB. (private property 400+ acres)
Jim Miller
103 U/SA
Old 11-07-2024, 01:57 PM   #145
Chuck Weissberg
Liked 57 Times in 27 Posts
Thanks for sharing...did you think @ someone in the states ordering your comp cam for you?
Originally Posted by goinbroke2 View Post
As you can see, it ain't pretty! But the video on the 9" got me thinking, is there specific locations to add the ears? As in, factory 8.8 is 4" from center of axle to center of upper control arm bushing. Is this ever checked? Since it never came with a 9", it needs ears welded on, but does NHRA check that it is at factory distance? Obviously moving the ear up or down would change the instant center which is an "advantage". Not too concerned as it's the same as factory but I was just curious since you can't "weld" on suspension stuff.
(or did I miss a perfect opportunity to shut the %$%^ up??) LOL!
Chuck Weissberg is offline   Reply With Quote
Old 11-09-2024, 11:21 AM   #146
Chuck Weissberg
Just letting you know I ENJOY your running commentary
Old 12-03-2024, 10:54 PM   #147
goinbroke2
Glad someone is, wife can?t stand it 😂😂.
Rolled under it again and pulled the valvebody. Stuck in another i had that already has a shift kit, but is forward pattern. I was going to send it to Broader but we haven?t had mail for a few weeks now🙄🙄 can?t make this up?
With the forward valvebody in it, fired up and all gears are good. PRND21
Jim Miller
103 U/SA
Old 05-06-2025, 07:35 PM   #148
goinbroke2
Been a long winter...So, now I've got cataracts in both eyes (waiting for surgery) Brother in law who is legally blind and mentally handicapped moved in with us as his mother went to a home. Life has changed...Since I have a milling machine, I needed a metal lathe, so I built one! Of course I needed to buy a lathe to finish it so now I have two, LOL! I'm definitely a mechanic, not a machinist though, lol.
But, in between a million other things, I decided that since pulling the reverse pattern valve body 5 times, went over it and over it, took it to a performance transmission shop and still.....no bueno. So, put the forward pattern valve body back in (with the shift kit in it) and was going to rebuild/replace the b&m shifter or the hurst or something to work and instead said why do it the easy way, LOL!
So instead, since I have a milling machine, I made my own shift gate for the stock shifter. Now thumb button in, first to second, button out, second to drive, in, out, in, out from 1st to park. Made a template out of aluminum then transferred it to steel.
Again, mechanic, not machinist, lol!
Next up is pull the fuel tank/etc.
Long time between updates but hoping to hit a non-S/SS race end of May just to find out what else I missed. Looking at the driveshaft, I'm thinking it's out of the tail of the tranny quite a bit..oh yeah, I moved the rear end around when I welded on the ears. (yes the wheelbase is stock) Driveshaft is out of a 4 door maverick because that was what I had..build one to fit?...that doesn't sound like me. LOL.
More to come.
ID:	72556   Click image for larger version
ID:	72557   Click image for larger version
Jim Miller
103 U/SA
Old 05-06-2025, 07:38 PM   #149
goinbroke2
Yes, I got the cam and carb from Mike Graham and the converter from Dave Turner. Also picked up a set of 5:14 gears to replace my worn out 4:86's. (as in WORN OUT!!)
Jim Miller
103 U/SA
Old 05-07-2025, 12:24 PM   #150
goinbroke2
Shifter is done, works great (until I get to the track?? LOL) While underneath I took another look at the driveshaft. I'm assuming it's when I put the adjustable upper arms on, but, regardless, the driveshaft is only engaged about 2" and there is 2" sticking out. I can wiggle it so I don't like it.
Went to pull the driveshaft and couldn't turn it...in neutral..got a power bar and went on a wheel nut, the sound of rust breaking free and voila, a free spinning rearend. The back brakes were rusted to the drums I guess, crazy humidity here.
So, got the driveshaft out and picked through the pile. Got a stock mustang driveshaft (about 6" longer than the 76 maverick shaft that was in it) So now I have to call A&J automotive to see where to get a driveshaft cut/balanced.
One step ahead, two steps back, lol!
I'll get the fuel system ripped out someday, have a doctors appointment this afternoon so I'm done for the day I guess.
Jim Miller
103 U/SA
