Old 12-21-2024, 01:03 PM   #1
Timothy Fletcher
Liked 83 Times in 5 Posts
Default 2003 Newmar Dutch Star
2003 (?03-?04) Newmar Dutch Star 4005 41? diesel pusher. 8.3 Cummins 350hp/1050torque, Allison transmission, Spartan chassis, 3rd owner, BANKS power programmer with interior gauges just plug it in and makes 425hp/1250torque.
Side radiator, 83k miles, (2) slides, 22.5? tires, air ride/air brakes, hydraulic levelers, Generac 7500 generator 1850 hours, (2) 13.5 low profile AC units, (2) furnaces, (2) sinks, window awnings, slide out trays, outside tv. 150g fuel w/dual side fill, 105g fresh, 65g grey, 45g black, 10g hot water, 32g LP tank.
This has been my families baby for the last 3-4 years and been absolutely perfect motorhome, no leaks, no delamination, straight as an arrow. Carpets, couches, chairs, dinette all great condition with no stains/rips/tears, couch folds out and still plenty of room to walk throughout. No rips on any awnings or slide tops. Everything works as it should inside and out. Drives straight, tows great and the factory 10K hitch has been welded and braced by CBR fab with a cradle built underneath to ensure no problems.
All tires match and are about 4 years old, all batteries are new in 2024, new converter/charger in 2024, new microwave in 2024, new fridge board in 2024, all new window shades in 2024. New main LED RV/Marine lights in 2023, new power sterring pump in 2023, new pinion seal in 2023. Oil, filters, fuel filter on the coach and generator are changed in FL each year when we start the season regardless of hours or miles. Have all records of everything mechanical ive done since owning it.
Vacuumed, washed each time before use, waxed, polished, and carpet cleaned twice a year. Cleaned the roof twice a year to keep build up and grime off of it. Has had anything it needed immediately, great overall quality and well-built. Have tons of pictures I can send.
Clean title in hand, ready to go
$55,000
Call/Text/Message Tim at 585-314-2455
Thank you!
Here is a link I found online to the spec sheet from the factory:
https://library.rvusa.com/brochure/2003dsdpbrochure.pdf
Dan Fletcher Racing
Stock / Super Stock
1792
Timothy Fletcher is offline   Reply With Quote
Old 01-14-2025, 09:25 PM   #2
Timothy Fletcher
Default Re: 2003 Newmar Dutch Star
SOLD! Thank you CR
Dan Fletcher Racing
Stock / Super Stock
1792
Search this Thread:
Advanced Search
