Go Back   CLASS RACER FORUM > Class Racer Forums > Competition Tech
Old 01-26-2025, 08:00 PM   #1
rod
Liked 20 Times in 15 Posts
Default intake gasket sealing?
has anyone used contact cement to hold intake gaskets in place?
I have 2 problem areas. divider wall & top of port.
thanks Rod in AZ.
rod is offline   Reply With Quote
Old 01-27-2025, 11:23 AM   #2
Run to Rund
Liked 56 Times in 29 Posts
Default Re: intake gasket sealing?
First I would check whether there is any gap one place vs. another meaning the heads or intake need to be "squared" and resurfaced. K&W Coppercoat spray stays sticky for days and would work well. It can be removed with lacquer thinner.
Old 01-28-2025, 12:28 AM   #3
FED 387
Liked 336 Times in 183 Posts
Best stuff is Permatex HYLOMAR M or equivalent--Patterson uses it on all their engines---FED 387
Old 01-30-2025, 02:43 PM   #4
rod
good tip thanks. Rod in AZ
