Old 02-08-2025, 02:23 PM   #1
L.Fite
Liked 498 Times in 244 Posts
Default 2002 Buick 3800
I got this LeSabre with a 3800...
Is has a upper intake coolant leak...
I can not see where it is coming from...
Is there any water in the upper intake plenum?
It's plastic with aluminum intake lower half.
I've cleaned and dried the top of the motor and it looks like its running around where the plenum and intake come together...
Puddles up on top of the intake and runs down the head onto the exhaust...
Tried snugging the bolts around the plenum don't seem loose, but there are a couple I can't get to with the tools at hand.
The motor is in the car and not taken apart...
Trying to avoid that.
Only has 46000 on it...
Was moms car and I'm keeping it because it gets 30+ mpg going down the highway...and averages 22...
Much cheaper than the dually for tooling around town...
Any 3800 mechanics out here?
L.Fite is online now   Reply With Quote
Old 02-08-2025, 03:08 PM   #2
Liked 1,908 Times in 427 Posts
Default Re: 2002 Buick 3800
Yes, they leak between the upper and lower intake, not a hard fix. Flush the orange garbage out and put good green antifreeze in it when you're done.
Old 02-08-2025, 04:08 PM   #3
L.Fite
Thank for the info.
What I was afraid of...
Wasn't sure there were any water passages.
Should be just gaskets and time?
Old 02-08-2025, 04:42 PM   #4
Thank for the info.
Yep. Took me a couple of hours on my Firebird. You'll have to bleed the cooling system.
Old 02-08-2025, 05:32 PM   #5
TOSTO RACING
TOSTO RACING's Avatar
Liked 662 Times in 187 Posts
Do what Alan said and make sure you check those 2 coolant elbows the GM ones are plastic and leak all the time!
24503423 elbow
12565082 elbow
gm numbers
Dorman makes metal ones also for replacement.
Also waterpumps are bad on those and it all looks like its leaking from the same area.
5664 GHI/SA
1985 CAMARO RED H/SA
1985 CAMARO BLUE I/SA
TOSTO RACING is offline   Reply With Quote
Old 02-08-2025, 07:32 PM   #6
BTR69
BTR69's Avatar
Liked 85 Times in 26 Posts
Check the coolant elbows as stated above. That's what happened to my moms car recently. Not a difficult fix, but still a pain in the arse.
William Kilduff
1970 Barracuda (still trailer jail, indefinitely?)
1968 Camaro SS/C
BTR69 is offline   Reply With Quote
Old 02-09-2025, 02:21 PM   #7
L.Fite
24503423 elbow
12565082 elbow
gm numbers
The leak looks like it's coming from driver side...
Pump and elbows already replaced a while back...
Old 02-09-2025, 02:23 PM   #8
L.Fite
Yeah it is...
Seems like you have to take half the car apart to work on these things!
Old 02-09-2025, 05:08 PM   #9
67 Post GS
67 Post GS's Avatar
Liked 49 Times in 11 Posts
I would go-ahead and replace the plastic upper intake all together. They will warp over time, and then you put a fresh gasket underneath and it will still leak. Dorman makes a replacement.
67 Post GS is offline   Reply With Quote
Old 02-15-2025, 11:24 PM   #10
4speedracer
Liked 10 Times in 6 Posts
The Dorman intake used to come with a different internal EGR tube to get the heat away from the intake. OE configuration would damage the intake, sometimes leak internal and hydraulic the engine. Would suggest doing the lower intake at the same time, the general used plastic lower intake gaskets also replacements can be gotten in metal with rubber inserts.
4speedracer is offline   Reply With Quote
