Old 02-28-2025, 10:23 AM   #1
Jeff Stout
Liked 706 Times in 283 Posts
Default Concrete Cleaner
Tried vinegar, water, purple power, baking soda.
The stains are half as bad. Anyone come up with something better that can do the job cleaning concrete. Typical oil spots and rust water stains.
Thank you
Old 02-28-2025, 01:59 PM   #2
Mike Gray
Mike Gray's Avatar
Liked 705 Times in 204 Posts
Default Re: Concrete Cleaner
Fresh oil - Kitty litter
Old oil - Super clean and sunlight.
Mike 7570 A/SA
Old 02-28-2025, 04:15 PM   #3
Bob F
Liked 16 Times in 11 Posts
Driveway try muratic acid.
Don?t breathe it in.
Bob F is online now   Reply With Quote
Old 02-28-2025, 05:46 PM   #4
Jeff Stout
Getting muratic acid now. Thanks.
Old 02-28-2025, 05:48 PM   #5
Mike Gray
Mike Gray's Avatar
Be careful it will eat away concrete. It will help with the rust (not oil) have plenty of water available to rinse off and follow trail as it will leave a stain of the water trail on your concrete if not scrubbed off well.
Mike 7570 A/SA
Old 02-28-2025, 06:26 PM   #6
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Mike, KNOWS. I wouldn't use muriatic acid if you've never worked with it before, surface degradation and cracks are a common result. Use Sure Kleen instead.
Old 02-28-2025, 10:50 PM   #7
Tom Meyer
Liked 354 Times in 120 Posts
Flame away, If out side use small amount of reg gas scrub with a broom cover with floor dry sweep it up, it will be spotless. Just did it today on my sons driveway from a tranny line leak. Tom
Tom Meyer 5240 SS Stock ???
Old 03-01-2025, 09:43 AM   #8
Frank Castros
Liked 2,753 Times in 974 Posts
I used drain cleaner and it worked well. About 90% successful.
Old 03-01-2025, 05:13 PM   #9
Jeff Stout
Hardware guy said same thing and while a nice driveway when washing off I have about 3 puddle areas and the along driveway is slightly higher. So wouldn't be able to remove all acid. I had purple power it really help alot.
Old 03-01-2025, 05:15 PM   #10
Jeff Stout
Ed, sure clean you feel alot stronger then purple power? If so then I'll try it.
