Liked 10,850 Times in 2,254 Posts
Bigger, Deeper, and oil further from the crank. Can the person approving this stuff read a ruler, scales or digital calipers. Reading the vernier on a micrometer maybe out of the question. When was the last time the NHRA tools got checked against a National Standard? How many SBC oil pans are painted black?
Liked 8,127 Times in 1,534 Posts
Larry, not a good idea to POKE the Bear. When you find out the answer to your question, please find out how the 66 Chevy novas got a deep sump pan also ….
Reading a ruler?
Liked 4 Times in 3 Posts
Cost me an engine, because we didn't check it out. Turns out to be a much larger pan than 5 quarts. And it's in the approved parts list
Kenny Miracle P/SA 310 Last edited by kwm; 03-06-2025 at 11:17 PM. |
Liked 997 Times in 201 Posts
That thing is so deep you will have to put 12 quarts or more in it to slow your ol 350 down. LOL
Liked 354 Times in 120 Posts
LSX/LS NHRA Drag Race Pan Kit, 7.5″ Deep, 6 qt, Wet Sump Aluminum Oil Pan 1025-NHRA
$1,085.18Each Stef?s 1025-NHRA aluminum drag race wet sump oil pan kit. Designed to fit Chevy LS installed in a 2010-2015 or 2012-2015 COPO Camaro. These pans 3/8″ thick side rails for leak free performance. Oil pump pickup, filter adapter and windage tray included. NHRA approved for Stock Eliminator For all Chevy LS/LSX Blocks Clears up to 4.250″ Stroke w/steel rods Drag baffle with trap doors Accel and decel ledges Aluminum bolt in sump tray Billet aluminum filter adapter Steel windage tray Fabricated aluminum oil pump pickup tube Magnetic drain plug Mounting hardware included 7.5″ deep pan holds 6 quarts in pan + filter
Tom Meyer 5240 SS Stock ??? |
The COPO, Drag Pack, and the factory Cobra Jet are all built from catalogs at custom shops. I do not have a problem with that
It is the stuff that is a direct replacement that is way wrong. The comparison is very similar to Larry Hodge and myself. We are both old racers but that is where the similarities end, but we have the same initials. He is regular size and I am slightly bigger by at least three quarts. One Larry is not a direct replacement for the other one. During having a piston approved I had to supply an OEM piston and my preposed accepted replacement all on my dime. Weight, ring lands placements, compression height, valve notch cc, wrist pin size, and appearance of the top of the piston. To do all of that it took NHRA some time and skill. My next question is what happened? Did the acceptance process turn into an income steam for NHRA or did they just lost sight of fairness to the racers. Last edited by Larry Hill; 03-07-2025 at 12:56 PM. |
Liked 5,137 Times in 1,960 Posts
I know they are out there but how did they get there. If they ant not the same there wrong.
Almost rite is still wrong! |
HRA Accepted Products
Car Brand Engine Manufacture Part Number Notes AMC 343/390 Milodon 30780 Chevy V6 CFR CFR-7459-Z CFR CFR-7465-Z CFR CFR-7466-Z Chevy Small Block/LS CFR CFR-7005-Z CFR CFR-7108-Z CFR CFR-7208-Z CFR CFR-9005-Z CFR CFR-9092-Z CFR CFR-9414-Z CFR CFR-9733-Z CHAMP PANS CP40 Milodon 30401 Milodon 30700 Milodon 30701 Milodon 30702 Milodon 30915 Milodon 31060 Chevy II Milodon 31501 Milodon 31502 Milodon 31503 Moroso 20180 Moroso 20181 Moroso 20182 Moroso 20211 Chevy II Moroso 20230 75-79 Monza Moroso 21151 COPO 427 Moroso 21804 Moroso 21807 Moroso 21808 Stef's 1025 COPO 427 Moroso 21149 LS Engine Moroso 20138 LS Engine Kevko Oil Pans 1050 Kevko Oil Pans 1050RH Kevko Oil Pans 1050NRH Kevko Oil Pans 2001 Kevko Oil Pans 2001RH Kevko Oil Pans 2001NRH Kevko Oil Pans 1069 Kevko Oil Pans 1069RH Kevko Oil Pans 1069NRH Kevko Oil Pans 1079 Kevko Oil Pans 1079RH Highlighted items designate recently added since last revision Updated Sep. 4, 2024 Stock Replacement Oil Pans NHRA Accepted Page 29 3/3/2025 NHRA Accepted Products Car Brand Engine Manufacture Part Number Notes Highlighted items designate recently added since last revision Updated Sep. 4, 2024 Stock Replacement Oil Pans NHRA Accepted Kevko Oil Pans 1079NRH Kevko Oil Pans LS1007 Chevy Big Block CFR CFR-9294-Z Milodon 30710 Moroso 20451 Kevko Oil Pans 1
