#11 |
Liked 308 Times in 103 Posts
any oil pan can be extra deep... if you drain enough oil out LOL
#12 |
The Milodon 30401 is a copy of the 6 qt Chevy Corvette SBC oil pan. 5 in the pan and 1 in the filter.
Moroso has an equivalent to the pan under P/N 20180 and it is also NHRA approved. Both pans have been approved as a replacement to the OEM 5 qt oil pan. Should NHRA ban the use of oil accumulators too? |
#13 |
Liked 997 Times in 201 Posts
Any companies pay oil pan contingency?
#14 |
Liked 662 Times in 187 Posts
After you guys figure out the oil pan you may want to look into how 396/375 Camaros (just one popular example we all know there’s many more
5664 GHI/SA 1985 CAMARO RED H/SA 1985 CAMARO BLUE I/SA Last edited by TOSTO RACING; 03-08-2025 at 08:24 AM. |
#15 |
Liked 10,896 Times in 2,255 Posts
Since the oil pans are allowed to be bigger two or three quarts, it would probably be ok to increase runner volume 25cc or valve size .040 on diameter, or make the head 10cc smaller.
#16 | |
Liked 1,912 Times in 429 Posts
Hyperbole much??? No insult intended, but, seriously, with all of the utterly egregious stuff in Stock, you REALLY want to worry about THAT oil pan?
Alan Roehrich 212A G/S |
#17 |
Liked 439 Times in 116 Posts
Larry
You must be Wineing to get HP off your combo, hit speed dial for Pat's Number |
#18 |
The truth is that having a bigger pan does not mean you will be gaining additional power. You make more power by controlling the movement of the oil inside the pan and diminishing windage.
