Old 02-02-2025, 05:03 PM   #41
Woodfin
Liked 288 Times in 109 Posts
Default Re: Square 10
Jake, local, top bulb brackets.
Old 02-03-2025, 06:12 PM   #42
Woodfin
A fine Monday afternoon to all. Be sure to notice the 5 - 7 crossfire enhancement.
ID:	72001   Click image for larger version
ID:	72002   Click image for larger version
ID:	72004   Click image for larger version
ID:	72005   Click image for larger version
Old 02-03-2025, 07:52 PM   #43
Frank Castros
Liked 2,752 Times in 973 Posts
Very clever build, I love it!
Old 02-13-2025, 07:40 PM   #44
Woodfin
Custom home built column
ID:	72019   Click image for larger version
ID:	72020   Click image for larger version
Old 03-12-2025, 06:22 PM   #45
Woodfin
The Square 10 will be the most bare bones, stripped down piece I have ever built. The interior will have a steering wheel, shifter, and seat. No dash, no carpet, no mat, maybe a couple of the 3M anti-slip pieces. I expect it to weigh around 2850 with driver.
Old 03-16-2025, 02:06 PM   #46
goinbroke2
Liked 405 Times in 158 Posts
Truck looks awesome, I do have some concerns/points I would like to add.
1) 5-7 swap works great but I think the wire you are using is too short, don't be fooled into thinking shorter wire between the two plugs will enhance the spark. (unless you already gapped it over the .125 minimum)
2) I tried the cable tie trick and while it will work, change to white ones as they hold the heat better. (I've never tried adjusting from outside, I'll assume this is with the engine off??)
LOL, Love the build, cool truck!
Jim Miller
103 U/SA
Old 03-16-2025, 02:41 PM   #47
Woodfin
Thank you. I need more tech help in my mature years, so I appreciate it.
Old 03-24-2025, 08:01 PM   #48
Woodfin
Off the tables and closer to the ground
Old 03-24-2025, 08:04 PM   #49
Woodfin
I have some exciting news. I have sold my home, relocated, and am beginning construction of a new shop. Stand by for more information.
Old 03-31-2025, 07:38 PM   #50
Woodfin
Roughing in some wiring and components
