Old 03-31-2025, 06:04 PM   #1
john ancona
john ancona's Avatar
Liked 187 Times in 58 Posts
Default 139 hp 302 ford help
Need help with the deck height , NHRA list a 302 at .047 Gasket ,and the deck height at .0005 is this correct
John Ancona 717 STK / SS
john ancona is offline   Reply With Quote
Old 03-31-2025, 06:58 PM   #2
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Default Re: 139 hp 302 ford help
Yes.
Old 03-31-2025, 07:36 PM   #3
john ancona
Yes.
Thank You for the help
so the piston is five tenths above the deck
Old 03-31-2025, 11:16 PM   #4
Mike Gray
Mike Gray's Avatar
Liked 705 Times in 204 Posts
Negative vs. Positive Clearance:
Negative clearance means the piston protrudes slightly from the deck surface, while positive clearance means the piston sits a bit inside the cylinder bore.
The .0005 on the chart appears to be a positive number so the piston should be below the deck. I assume if it’s assembled .0005 above a .048 gasket gets you back to correct deck clearance.
Mike 7570 A/SA
Old 04-01-2025, 12:49 PM   #5
Dwight Southerland
Thumbs up Re: 139 hp 302 ford help
Originally Posted by Mike Gray View Post
The .0005 on the chart appears to be a positive number so the piston should be below the deck. I assume if it?s assembled .0005 above a .048 gasket gets you back to correct deck clearance.
Yes.
Old 04-01-2025, 07:34 PM   #6
GTX JOHN
Liked 2,513 Times in 701 Posts
Basically, a Zero Deck Piston for all practical purposes.
John Irving
741 Stock
741 Super Stock
Old 04-03-2025, 07:57 AM   #7
Liked 10,944 Times in 2,259 Posts
For longevity of the block it might be best to start with a deck clearance of .010 to .015 if gaskets are available to bring the number to .048. If is easier to skim cut the block in the future than to shorten the rods or de-stroke the crank to get to the legal numbers.
Old 04-03-2025, 12:32 PM   #8
B/S 428
Liked 154 Times in 34 Posts
The early 302 blocks (68-72) deck height are about .020 lower than the 73 and up 302 blocks so with a early block you're close to 0 deck height and with a later block you're about .020 in the hole. Brian Seaberg 627
B/S 428 is offline   Reply With Quote
Old 04-06-2025, 10:36 PM   #9
GTX JOHN
Cometic has always made us whatever thickness gaskets we needed
to get deck and gasket height whatever we have need to be legal.
John Irving
741 Stock
741 Super Stock
