View Poll Results: Yay or Nay
This is a net good 86 43.88%
This is a net bad 52 26.53%
Don't care, I'm going to stay in my lane 58 29.59%
Voters: 196. You may not vote on this poll
Old 06-23-2025, 01:59 PM   #41
GUMP
Default Re: Toyota Supra Class Prediction
Originally Posted by Sgrossi7158 View Post
Daren, thank you for the response to my question. I think what you are doing in terms of adding an exciting new car/combination to Stock Eliminator is a good thing and your hard work should be commended.
Thanks!
However, one does not have to look back too far to see the results of what I believe is over generous NHRA HP ratings related to new cars/combinations.
For example, 2010 INDY; 11 of the top 16 qualifiers were 2008-2010 entries.
2011 INDY; all top 16 qualifiers were 2008-2011 entries.
I guess that was all Drag Paks and Cobra Jets? My thought is that it would be better to look at more years if you want to make a fair argument. I can think of more than a few combinations that are really strong when the AHFS is turned off.
In my opinion, new cars/combinations in Stock Eliminator should be competitive, but they should not be dominating classes full of previous top qualifiers that have been flogging out there combinations for the past 20+ years.
That assumes that the performance increases are all due to "flogging". But, not "enhancements". Why shouldn't a new car be Bad ***** right out of the box?
Daren Poole-Adams
NHRA Stock/SS 2007
Old 06-23-2025, 05:36 PM   #42
Liked 1,952 Times in 439 Posts
Originally Posted by GUMP View Post
Thanks!
Why should a new car immediately be able to negate all of the hard work, development, and investment of combinations people have had for a long time?
Old 06-23-2025, 06:02 PM   #43
GUMP
People were asking pretty much the same questions when the "supercars" ruined everything in the sixties....
Daren Poole-Adams
NHRA Stock/SS 2007
Old 06-23-2025, 06:07 PM   #44
"It's happened before" is no excuse for it to happen again. History is to be learned from, not repeated ad infinitum and ad nauseum.
Old 06-23-2025, 08:03 PM   #45
GUMP
I wasn't talking about the cars. I was talking about the crying...
Daren Poole-Adams
NHRA Stock/SS 2007
Old 06-23-2025, 11:19 PM   #46
Dyno
Dyno's Avatar
Liked 695 Times in 206 Posts
Default Re: Toyota Supra in Stock Eliminator (Poll)
Last year at Indy, there were 5 ?Newer FS cars? in the top 16 for Stock. It seems to have leveled out from 10 - 12 years ago.
Old 06-23-2025, 11:53 PM   #47
Rory McNeil
Do you honestly think that "10-12 years" is a reasonable amount of time for soft make believe paper combinations to "level out? Certainly you must also remember how many years it took some of the modern EFI cars, like the 4th gen Camaros (and Firebirds), with both the LT1 and LS engines to finally move up 5 or 6 classes, and how many older combinations were essentially "Robbed" in Class or heads up races in eliminations.
NHRA 6390 STK
M/S 85 Mustang
Old 06-24-2025, 07:47 AM   #48
Crisco
Liked 47 Times in 21 Posts
Congratulations on having 2(!) threads about your car.
Crisco is offline   Reply With Quote
Old 06-24-2025, 11:06 AM   #49
goinbroke2
Liked 405 Times in 158 Posts
Reminds me of flathead fords that were 90hp. Bored/stroked/relieved/blown and they get 200hp! Then in 55 the overhead valve sbc was introduced with 200hp in a family car.
Technology is great, but shouldn't replace hard work. So the question becomes, how do you stop newer technology from dumping all over older tech that was messaged to get where it is?
Factor it correctly.
What happened when fwd cars came out? The hp/weight didn't take into account of the natural problem of pulling the car compared to pushing the car so they were factored by themselves (fwd classes)
What happened when turbos became common? Spec's for turbos to prevent "cranking it up and dominating" (buddy ingersol turbo pro stock)
What happened when blowers became common? Pulley dia spec's.
The common denominator is that newer tech is "better" than old tech so adjustments have to be made. Put it in a class that it doesn't immediately dominate or bump it up a class (add hp)
Not against toyota joining the fun, just want it done fairly. It's all a moot point until the first pass is made, then if it's 1/2 sec off the index and has to start like everyone else, fine. If it's -1.00 out of the gate then yes, adjustments need to be made.
You can't factor a 1965 sbc the same as a 5.3ls.
Jim Miller
103 U/SA
Old 06-24-2025, 11:51 AM   #50
GUMP
So, in your world. I can build a 1969 Camaro with a 396/375 that will run 1.20 under and not use one original part in the entire car, that would be OK? But, if I build a new Supra from the ground up using the same rulebook and it runs 1.00, it should be penalized?
Daren Poole-Adams
NHRA Stock/SS 2007
