Old 09-08-2025, 02:46 PM   #11
Jeff Stout
Liked 708 Times in 285 Posts
Default Re: av gas?
Originally Posted by Dan Bennett View Post
Not an issue for race cars, but if you have a street driven musclecar I found a problem.
With high c.r. like LS6 and L78 and even a Stage 1, it would always blow a baffle loose in a stock muffler. At the time we had a small municipal airport and no one cared if I pulled up to the pump for LL100.
Later I read info that the problem was caused by the LL100 being too "hot" or too "dry" and therefore caused the problem, but not enough detail was given for me to understand what that meant.
It creates heat and way less water droplets due to planes flying high enough and weather became very cold
Old 09-09-2025, 09:09 AM   #12
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 319 Times in 108 Posts
Default Re: av gas?
Originally Posted by Jeff Niceswanger View Post
Hi Mike. In 25 years of racing the SS'er I only failed with C-11. Once we had to take an entire drum back. Hot, muggy, hi humidity tracks was a problem for us and C-11 plenty of times. We never took the fuel out of the car after races, and it had a plastic Jazz cell. Maybe if we took the C-11 out and stored it in steel cans it would have helped. But C-12 never failed along with C-25, all the Sunoco fuels, even while leaving them in the plastic cell for extended timeframes. We did of course take the ERC out. Even after swapping ERC with anything else, our house smelled like ERC until the underneath was wiped down. That stuff STUNK>>>>
I only have had C-11 not pass once, had been in cell for 2-3 weeks. after that i started pumping out of cell and storing in metal cans,no problem since.
I have had it pass at two and a half to three years old from the metal drum.
Old 09-12-2025, 02:29 PM   #13
gregcharger72
Default Re: av gas?
I came across this interesting read the other day relating to fuel.
https://www.yellowbullet.com/threads...g-fuel.170626/
and this one as well related to av gas.
https://bobistheoilguy.com/forums/th...g-read.238415/
Last edited by gregcharger72; 09-12-2025 at 02:31 PM. Reason: add an additional thought.
gregcharger72 is offline   Reply With Quote
