Liked 5 Times in 5 Posts
Is there a resource or rule of thumb to DYI drilling and screwing rims to slicks? Slicks spinning on rims. moving about 1/4"-3/8" ea. pass.
28.5X10" M/T slick.
88 Mustang 533 BBF N/A |
Sponsor
Liked 717 Times in 121 Posts
STK 308 SS 3088 |
Liked 888 Times in 239 Posts
before you drill the rims ,you might want to try an old Stock /Super stock trick.
Break the beads and spray the rim beads and tire beads with AquaNet hair spray. let it get tacky and reinflate the tires . you might get a small movement on the first hit ,but they usually stick after that.
Liked 56 Times in 29 Posts
I blast the bead areas of the wheels with aluminum oxide media, then install the tires dry.
We're going with rims screws. We are leaving off two step @ 3600RPM. Want to leave at 4000RPM. Also late in season to break beads on the hope hair spray works. FYI have you looked at the price of aquanet? Lol.
Liked 14 Times in 9 Posts
4000 lb car 1.77 60 ft, 9" slick. 3M weatherstrip adhesive, no screws, no slippage, pulls lt/frt tire
Liked 68 Times in 25 Posts
I use Permatex Hi-Tack cement on 29.5x9 M/T and chrome Cragar SS. 3800lb. stick car leaving at 5500. Coat the tire bead, then the wheel, let it tack up and repeat then mount. Messy but works like a champ and cleans up easy with lacquer thinner.
