Old 11-11-2008, 05:32 AM   #11
Barney B
Barney B's Avatar
Default Re: Motorhome help
Mine is a 02 Gulfstream V-10, bought it new, 37000+ miles, had a recall on the fridge, 28', foot extra tall, dragster, golf cart, I am happy with it.
Like said before, have the hitch done up good and arange your trailer for the least amount oftongue wieght. I think tongue wieght is the key.
Also, mine never goes into overdrive until I am on the hy-way
BB
Barney B is offline   Reply With Quote
Old 11-11-2008, 10:25 AM   #12
Freddie
Freddie's Avatar
Liked 3 Times in 2 Posts
[QUOTE=Jason Oldfield;91434]Was it worth it? I've been toying with the idea of putting a Banks system on my 454 RV for a couple of years. I'd love to hear a glowing review.
QUOTE]
Jason I cant really say on this coach because it was on it when I got it, but this coach tows a whole lot better than my 32' bounder did with the v-10. and being its a 460 base engine, it has the C-6 trans so no trans worries here.
NHRA: Comp 2200 - S/C 2201
NMRA 2012 Outlaw 10.5 #10
Freddie is offline   Reply With Quote
Old 11-11-2008, 09:29 PM   #13
craig addis
I have been looking at c class motorhomes with ford v 10 and 4od trans .are the chassis not strong enough for a 28 ft trailer? I see very few of them at the races. There are tons of them for sale, but i wondered why noboby uses them. Thanks
craig addis is offline   Reply With Quote
Old 11-12-2008, 07:35 AM   #14
Freddie
Freddie's Avatar
big differance in chassis from the class C to the class A. A friend of ours uses a class C with his 24' trailer, and hates towing it anywhere, we used my motorhome to take hit trailer to a race not long ago, and he was amazed at how much better it towed.
His is now for sale also.
Old 11-12-2008, 10:41 AM   #15
Dean Oliver
I just bought a '07 Winnebago Class C 31' Outlook earlier this year. I use it to pull my open trailer, and I honestly cannot tell that it is back there. I talked at length with Marc LaBrecque at Diamond RV before I bought this unit and his advice was extremely helpful. The Winnebago units are truly better made motorhomes than many of the other brands that I looked at. Mine has a 215" wheelbase and has the rear air springs. This is my first motorhome, so I really don't have anything to compare it to but I have been pleased with how well it drives and with how it pulls the trailer. I plan on maybe boxing in the frame extensions at some point, but as Marc pointed out, it is probably not necessary with the Winnebago and my current trailer.
The only issue I have is, of course, with fuel mileage. It has the V10, and gets about 7 mpg or so without the trailer and about 6 mpg with it. Anyone have any suggestions on how to improve this? I usually drive about 67-68 mph with the engine turning about 2400-2500 rpm. I called Hypertech and they told me that they do not have a programmer for it yet, but they are working on it. I've heard good things about the Banks systems, but it seems like the payback would take forever.
Dean
Dean Oliver is offline   Reply With Quote
Old 11-12-2008, 11:25 AM   #16
Bill Harris
Liked 26 Times in 13 Posts
I started out looking for a class C but found my way to a class A instead. Maybe I'm too anal, but I tend to pay attention to the mfg specifications and the class C chassis don't have enough GCWR to tow most enclosed racecar trailers. The F450 chassis has a GCWR of 20K lbs and most 26' to 32' class C's use up 14,500 of that in their own loaded weight (GVWR). You only have 5500 lbs of capacity for what you are towing. You might get away with an aluminum trailer and a really light racecar and get it down to 5500 lbs, but it's not likely. A trailer-toad would probably really help in this case. An open trailer might work pretty well.
The Ford class A chassis has a GCWR of 26K. I purposely looked for a short overall length with a long wheelbase and a fairly low GVWR to maximize the towing capacity.
I see quite a few Ford chassis class C's, even quite a few E350 chassis which only have a GCWR of 17,600 lbs, towing pretty substantial trailers, so it CAN be done. I wouldn't want to do it myself, however.
Bill Harris
ex 2172 STK
ex 2272 S/S
Bill Harris is offline   Reply With Quote
Old 11-12-2008, 02:09 PM   #17
Roger Weaver
Roger Weaver's Avatar
I use a 2002 class A motorhome v10 to tow a 24 foot trailer with a s/st car and golf cart.Have had real good luck with it,hitch has extra braces and air bags.This year I bought a Trailer Toad and am very happy with it.Takes all the load off the coach, much better ride,took all the sway out when you pass or get passed by the big trucks.Worth looking at anyway. Trailer Toad ask for Jok 319-404-7001
Old Mustang 2012 US Nationals Super Gas Champion
3461 S/ST & S/G
Roger Weaver is offline   Reply With Quote
Old 11-12-2008, 10:52 PM   #18
John DiBartolomeo
We (http://www.drcraceproducts.com) do quite a bit of motorhome hitches. Your only concern should be a hitch which is mounted properly. Gasoline chassis motorhomes need to use the weight distribution bars as well as some sort of sway control. Diesel pushers with air ride suspension don't require weight distr. bars but by installing them loosely, they will take out the bounce you'll get when you hit bumps. You won't have any problems towing with this unit and if this is your first motorhome, I think you're really going to be happy you have it. If you have any questions, feel free to call us at 609-209-9979.
John DiBartolomeo
DRC Race Products
DragRacingActionOnline.com
