Old 04-04-2007, 12:32 PM   #11
Chris1529
Liked 70 Times in 29 Posts
Default
I also run the small bellhousing. 157 tooth w/tci flex plate.
Performance Automatic makes the spacer plate that works great. Make sure you get 50 oz balance componets.
I may be wrong, but if you use a case fill trans, you probably have to use the small bellhousing to get a dipstick to fit. I believe most of the large bellhousings came on the pan fill type.
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 04-06-2007, 04:09 PM   #12
Earle Holt
Liked 4 Times in 1 Post
Default
The flexplate should have a counterweight welded to it from the factory. (Not sure why yours wouldn't) From a transbrake perspective, I don't think it would matter what trans you use. The valve bodies are interchangable. I have both a small bellhousing C-4 that is case-filled and a large bellhousing C-4 that is pan filled and both worked fine.
Earle Holt 1055 Stock
Earle Holt is offline   Reply With Quote
Old 04-07-2007, 08:36 AM   #13
Larry Munk
Default
If you're only going to bracket race it put a powerglide in it. Lots cheaper in the long run.
Larry Munk is offline   Reply With Quote
Old 04-07-2007, 02:07 PM   #14
Chris1529
Default
I would like to believe you are only joking about the powerglide.
Put and AOD in it and a 456 gear in the the rear end and drive it on the street also.
Chris Bowman
1984 Mustang GT350
Old 04-07-2007, 04:46 PM   #15
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Default
Well here's the "PLAN" ....I'm going to put on a set of E7TE heads that I have that have been ported. Add the C4 the 8.8 & let Marissa drive it /race it for a year or two. Then I'm going to let her buy her a new Mustang GT conv & I'm going to take the little car & make a GT/MA car out of it. That's the plan anyway.......
novamoation
Old 04-09-2007, 07:44 AM   #16
Chris1529
Default
sounds like a good plan to me.
Chris Bowman
1984 Mustang GT350
Old 04-10-2007, 11:10 AM   #17
Chris1529
Default
Are you going to put the original 600 cfm Holley on it?
Chris Bowman
1984 Mustang GT350
Old 04-10-2007, 08:23 PM   #18
greg fulk
greg fulk's Avatar
Default
Yes sir!
novamoation
Old 04-11-2007, 12:21 PM   #19
greg fulk
greg fulk's Avatar
Default
I've seen no pictures my Polhill! mgfulk@yahoo.com
novamoation
Old 04-14-2007, 01:13 PM   #20
wsp
Default
small...same as me
wsp is offline   Reply With Quote
