Liked 11 Times in 5 Posts
We have a couple customers that run F-body cars and cant seem to get them to work very well.
They have QA-1 shocks all around. BMR lower control arms, and spoon mid-mount torque arms, subframe connectors and a cage. I see a lot of fast stockers really working well. These cars our customers have are making about 600HP. Can someone help me out with some suggestions PLEASE ! Any help would be greatly appreciated. Thanks, J.C. Kowalsky Racing Engines (434) 821 6107 J.C. Childress (434) 665-9541 |
I HAVE A 91 FIREBIRD THAT I AM RUNNING IHRA CRATE MOTOR STOCK,THE CAR WOULD PULL TO THE LEFT ONE TIME THEN IT WOULD PULL TO THE RIGHT IT WAS A HAND FULL BECAUSE YOU NEVER KNEW HOW IT WAS GOING TO LEAVE,THE LEFT FRT TIRE WOULD RAISE UP AND THE RIGHT WOULD NOT,I CALLED JOE RUSSELL AND PURCHACED A SET OF HIS TRACTION BARS AND THAT CURED THE PROMBLEM,THE CAR IS NOW FUN TO DRIVE.I HOPE THIS INFO HELPS
Allen Lambert |
Liked 882 Times in 236 Posts
Russell's bars are definitly a must to limit housing rotation .... I would also get rid of the short torque arm in favor of a stock length arm. ... Even a reinforced stock unit will work well when used with a crossmember attached to the connectors. Russell can help with that too. Shock settings are really critical if this is a small tire car , too much hit on the tire, and the shock bump setting may not be able to keep the tire hooked up. I have learned that trick suspension parts are not always necessary to put one of these cars on the bumper. ..... Tom
How can you get in touch with Joe Russel ?
Doesnt Al Corda run pretty fast in one of these cars with small tires on it ? How about Woodrow Josey? I would love contact info for any of these guys....or anyone thats in the know on the suspension for these cars. Thanks J.C. Childress |
You can reach Joe Russell@330-484-2960, or 330-268-6374. His parts are basic ,no nonsense stuff. .. I' ve used them on several F-bodies and they work! .. Current B and C/FIA record holder cars have them. .... I think Corda's car is a Wiebe car,also a LS1, Big difference in weight distribution over a LT1 motor. .....Tom
Liked 150 Times in 43 Posts
Brand New Traction Bars for F-body Stocker. Built by Joe Russel. Bars are powdercoated and ready to install.
$ 350 OBO Call Terry Allison at 724 462 6444 Aaron Allison Super Stock GTAA Stock B/CM
Aaron Allison 395 STK, 395 SS, 3395 SC |
I tried both of those numbers. Never got anyone, but did leave a message.
Any other advice ? Thnaks for the help so far. J.C. Childress (434) 665-9541 |
Liked 1,583 Times in 582 Posts
I have also tried both numbers, left messages and even a fax, but no response.
JOE RUSSELL IS HARD TO REACH BUT IF YOU LEFT A NUMBER HE WILL CALL YOU BACK
Allen Lambert |
Why not buy a set of already done traction bars. These bars are even powder coated.
