Old 04-02-2007, 11:29 PM   #1
ss wannabee
Liked 7 Times in 7 Posts
Default 33 or 35 spline 12 bolt axles?
We're checking out axle & spool kits for the Chevelle wagon. Which would be better in a lower-class SS car? Nothing 'trick' here...talking about a length maybe 2 inches shorter than stock.....PG trans and drum brakes. Best axle bearing.......maybe the Ford type? Any favorite mfgrs? What about lightening? Might try a 4-speed later in the car.....would I be better off with a Dana?
ss wannabee is offline   Reply With Quote
Old 04-03-2007, 12:14 AM   #2
FED 387
Liked 333 Times in 180 Posts
Default
Take a look at moser they pay qualifying $$$ I think --Get a 9 inch ford 35 spline axles you will probably never ever break one---- a milllion different gear ratios ---get big ford or olds bearings same size and you can go nuts with all the lighting/scalloping/boring to the axles too----If you want to you can get a 12 bolt dropout center for the ford too----change ratios in 20-30 min with the ford instead of 1 1/2 -2 with the 12 bolt----just my opinion but unless you enjoy laying on your back busting your nuts to crush the sleeve on a 12 bolt I would do a ford--- Been there done that both ways will take the ford hands down---Comp 387
Old 04-03-2007, 12:16 AM   #3
FED 387
Default
That should be 1 1/2 - 2 hours!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Comp387
Old 04-03-2007, 08:09 AM   #4
dannyw
dannyw's Avatar
Default
Call Danny Waters Jr. @252 525 1605,He is a rep for Moser and get drop shipped to your door.THANKS
dannyw
Danny Waters, Jr.
dannyw is offline   Reply With Quote
Old 04-03-2007, 09:47 AM   #5
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
Default
If you set up your second ring and pinion (correct shims, etc.) and use a solid bearing spacer (no crush sleeve), you can change the 12 bolt as fast as you can change the 9". And it will be cheaper to build the 12 bolt. The major downside I can see for your situation is that you are going to run a 283 and the ratios you will need (6.00+) are much stronger in the 9" or a Dana than in a 12 bolt.
Old 04-03-2007, 10:08 AM   #6
Adger Smith
Liked 880 Times in 311 Posts
Default
If you are going to price Moser concider calling Lynn McCarty at 317-839-8378 Lmc3470@aol.com
He is very competive on his pricing and Disabled Youth Awareness gets a donation from the sale. So you will help yourself on price and help DYA at the same time.
Adger Smith
Adger Smith (Former SS)
Old 04-03-2007, 03:38 PM   #7
ss wannabee
Default
Thanks guys!
