With indexing the AR3933 spark plugs. If the crush washer does not give it the right position and you install the moroso washer (1 of 3) are you supposed to reinstall the crush washer or leave it off the spark plug since you have a indexing washer on it?
Liked 11 Times in 8 Posts
I've always lrft the washer on the plug, makes sense to seal against the indexing washer. Joe
Joe Buchanan SS/BX 3117 |
Liked 22 Times in 22 Posts
what is the widest gap some run on their plugs and what benefit have you seen?
don,t have one |
Liked 584 Times in 94 Posts
Randy, wide spark plug gaps went out with ignition points. With todays MSD's and most other manufacters electronics, there is no reason to run more than .025 gap. As a matter of fact, if your trying to run, say .040 - .050, close the gap down to .020 - .025, and you'll see a performance gain. At least that been my experience. ( and don't forget to have your plugs Cryo'd. - go kart trick! )
Liked 334 Times in 181 Posts
on AR3933 plugs leave the gap alone --run em as they come from the factory just check to make sure that the gap did not close up ratteling around in the boxes---Comp 387
Liked 564 Times in 66 Posts
"( and don't forget to have your plugs Cryo'd. - go kart trick! ) " - Jim Bailey
Hey Jim, Is there a shop you would recommend for doing this? Bill |
Liked 5 Times in 3 Posts
Bill I think their's some guy up in Ohio that dose it when he's not playing with a nitro funnycar!
Liked 2 Times in 2 Posts
Come on now guys... what's the reason or benifit of cryo treating plugs?
Kris Rachford 69 Cobra 428CJ 4 Speed C/S 3032 |
It keeps em cool...
Bub Whitaker |
Liked 20 Times in 12 Posts
I don't know about the cyro , but I do sell alot of Autolite AR 3910X and AR3933X to the go cart guys. It's a surface gap plug that has proven to be worth some big gains on their dyno.
Rich |
