Old 02-03-2010, 02:27 AM   #1
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Question how much Hp?
Hello guys...I have a buddy @ work that has a 69 Fairlane 500 with a 428Cj his ? is how much Hp dose he need to run S/ST? We are redoing the engine this winter & it's now time to buy a cam. Here's what he has 428Cj flat-top engine good set of heads Victor intake 850 Holley C6 with a pro-tree brake 8" TCI converter 5.14 (or 4.56) gear 31x10.5 W slicks with a ladder bar set-up. The car is around 3200-3300 with him in it (he's 140lbs). Thanks for any input
Old 02-03-2010, 08:04 AM   #2
SCOTT SST2871
Default Re: how much Hp?
I would think with a 3300 lb car you would need 500 hp minimum,which should be fairly easy with that combo
scott fifield
SCOTT SST2871 is offline   Reply With Quote
Old 02-03-2010, 08:43 AM   #3
Bob Verwold
Bob Verwold's Avatar
I'm running 600 hp and one of the slowest in the field (carrying 3020lbs). if that helps ?
Bob Verwold is offline   Reply With Quote
Old 02-03-2010, 01:26 PM   #4
greg fulk
greg fulk's Avatar
Thanks guys! He's not worried about a lot of mph right now just wanting to get it to run like 10.70's so he can try this & see if he likes it.
Old 02-03-2010, 03:45 PM   #5
Floyd Staggs
Floyd Staggs's Avatar
Liked 229 Times in 99 Posts
I've got 700+ and all I get is 10.70 @ 122 @ 4000 lbs.
Floyd Staggs 787 SST
Floyd Staggs is online now   Reply With Quote
Old 02-03-2010, 04:12 PM   #6
Bob Verwold
This he wouldn't be you getting tired of all the stock BS would it ?.....
Old 02-05-2010, 02:23 AM   #7
greg fulk
greg fulk's Avatar
Talking Re: how much Hp?
No I do have a buddy @ work with a 69 Fairlane 500 that wants (or thinks he wants) to go S/ST racing....That being said if I sell the Cutlass I think I just my start building a S/ST car...that Super Series @ Trails looks REAL good to me!
Old 02-05-2010, 01:42 PM   #8
Bill Baer
Smile Re: how much Hp?
Well here' the math:
ET from HP (1/4 mile) = (WEIGHT / HP)^.333 * 5.825
(note the little ^ symbol indicate an exponet i.e you need to take the value to that power)
Keep in mind that this is rear wheel HP not flywheel HP as measured on a Dyno. if your running a torque converter you will lose ~ 8-10%
So if you calculate (3300# /563HP)^.333 X 5.825= 10.50ET but thats rear wheel HP
so you need another 8% to at the flywheel or 563(HP) x 1.08 =~608HP to run 10.50
10.90 calcs out to 544HP but that would leave you no room to account for bad air,bad tracks etc.
Try this web site for more racer math
www.freewebs.com/soslo/formulas.htm#hp_from_et
Hope this helps!
Old 02-05-2010, 05:40 PM   #9
SSTRACER323
SSTRACER323's Avatar
Send a message via Yahoo to SSTRACER323
Baer,
When we dyno'd my motor at Troys it showed 496 on the dyno.
My car weighted 3020 with me and i went 10.25 @ 131.00 on good day
very bad day i would go 10.42 @129.00.
600 hp in my car and it would fly, even with my big *** in it.....
The Doughboy
Lee Lones
S/ST 323L
SSTRACER323 is offline   Reply With Quote
Old 02-06-2010, 09:43 AM   #10
astikhossw
astikhossw's Avatar
Liked 20 Times in 9 Posts
How about finding yourself one of the ford svo v-6 engines and run s/st at 2000 lbs. and 550 hp easy with a really conservative camshaft,should run deep in the nine's at over 135,thats how i an doing it.
astikhossw is offline   Reply With Quote
