Old 03-21-2010, 02:22 PM   #1
shockme668
shockme668's Avatar
Default Manual steering box on chevelle
I have a 1970 chevelle about 3300lbs it is a drag car. I have a manual steering box with the stock suspension parts..The front end has no slop in it, but the car drives like a boat..I have to fight it to keep it straight..I was going to replace the steering box with a vega box or rebuild this one..i hope some one can give me some advice...Thanks
shockme668 is offline   Reply With Quote
Old 03-21-2010, 05:51 PM   #2
Greg Reimer 7376
Liked 727 Times in 221 Posts
Cool Re: Manual steering box on chevelle
Check your Pittman arm. All 64-72 Chevelles use a Pittman arm that's the same length,but the tapered hole on the small end is larger on the 66-67 models. The 68-72 had a rather small hole in it. The proper fix is to locate a 68-72 arm,but if that's not happening,the Moog catalog shows the 66-67 drag link. If you put the earlier drag link on your 70,you need to readjust the tie rods considerably to get your toe in correct again.To compound the confusion, the number forged into the Pittman arm is the same. The holes were machined later,which explains how a part with one part number had two different size holes on them.
Old 03-22-2010, 12:52 AM   #3
Run to Rund
Liked 56 Times in 29 Posts
Default Re: Manual steering box on chevelle
Also check the overcenter adjustment--the stud and locknut on the top cover. Don't overtighten it but snug it just enough to remove slop between input turning and output response.
Old 03-22-2010, 11:45 AM   #4
shockme668
shockme668's Avatar
Adjusting the overcenter and lubed the front end...Took the car around the block it is a new car...Thanks for the help.......
Old 03-29-2010, 12:59 PM   #5
Nick Finney
I have a 1969 Buick Special with a Chevelle manual steering box on it and my car steers like a dream. I have been as quick as 131mph, and felt like I could have let go of the wheel as it was so smooth. I believe I have the factory pitman arm, as it should be the same one as the Chevelle. If this helps any great, if not I just wanted to share my experience so far with the manual box.
Nick Finney is offline   Reply With Quote
