Liked 165 Times in 51 Posts
What %converter slip is normal for a STOCK Elm. car?
It depends on the combination.
Alan Roehrich 212A G/S |
An average car will see around 12-14%, maybe a little more. The problem is that they need stall to get off the line, but cannot pull enough gear on top and make enough RPM and HP to really lock up a converter and make it efficient.
Liked 20 Times in 12 Posts
So I take it that if you have 8-10% you have a very efficient conv? I am speaking of a sb stocker. How do you determine the % correctly?
Robert |
Well, with a car that needs a ton of flash stall to get off the line good, but cannot turn a lot more RPM and make good power above that flash stall, yes, 8% is pretty good. That can be difficult with a lower HP stocker that doesn't turn a lot of RPM. If your finish line RPM is more than around 1500 RPM higher than your flash stall, and is also more than 800 RPM higher than your peak HP, it can be hard to get a converter to couple up really well.
Your finish line RPM and the MPH it should give, with your gear ratio and tire size, compared to your finish line MPH, will let you know about what your slippage is. Of course, to do that, you are assuming the lights for the MPH clocks are set very accurately. That might be a big assumption, considering the variances you see in how well they are set of the starting line.
Liked 67 Times in 30 Posts
Robert, to figure slip multiply your mph say 114 x gear ratio 5.13 x 336= 196499 then
divide by tire height 29.5 = gives you a rpm of 6661 then multiply by 1.08 for 8 % =7193. just enter your correct values. mph x gear ratio x 336=@ then divide @ by tire height =true rpm with no slip and multiply by 1.08 for 8% 1.09 for 9% and so on to get your final rpm .
Ron Mattson 5015 STK Last edited by ron mattson; 06-15-2010 at 04:06 PM. |
Liked 20 Times in 9 Posts
what if you only come up with one or two percent slip.
It's pretty rare to get below 4% to 5%, in most cases anyway. Check your math, and check your actual tire size.
Liked 973 Times in 310 Posts
Most flogged out combos will have less than 5% slippage. Works on our car!
