#11 |
Liked 359 Times in 103 Posts
Meziere without a doubt.
The family races and uses their own products. My 2 Cents Rick Cates |
#12 | |
Great starter and I did get my money's worth! My new engine required a larger gear because I went to a smaller flywheel. So it's a custom. I called Greg Porter and told him "no rush" as the engine is far from done. It arrived about 7 days later! I haven't used it yet but I think it will crank over a diesel, it's still a mini and the price was right. I would suggest a call to Greg.
Jeff Lee 7494 D/S '70 AMX |
#13 |
Liked 544 Times in 213 Posts
Avoid the Jeg's branded starters. I bought one and the drive slipped almost from day one. I thought it was initially a mesh issue but after some investigation I realized the drive was the problem. Installed a new drive and it works fine now......
Never had an issue with either an East Coast or Tiltons. Big Block engines with high compression on gas or alcohol injected.
#14 | |
Liked 6 Times in 4 Posts
#15 |
a AC delco starter from a vortec chevrolet pickup is a good choice for a chevy v-8. it is small comes with a heat sheild and you can get one just about anywhere.
#16 |
Liked 126 Times in 61 Posts
Call Frank at Franks Auto Electic in Kearny, NJ. Frank makes a great mini with a 9310 pinion.
#17 |
Frank passed away last year.
Steve Calabro 1199 STK, SS |
#18 |
Liked 54 Times in 27 Posts
check out www.robbmcperformance.com
#19 |
Guest
Posts: n/a
Tilton, I bought the one for my car used in 2002. Still works, just had to replace the drive return spring last year. Spring and retainer cost 27$ My brother used to Work for IROC that is now gone. He told me stories of when they used to load the cars in the trailer, they would put the trans in 1st gear and use the starter to move up and into the trailer. They are the best
#20 |
I use the HOUSE OF PAYNE starter. They are built by Mark Payne that runs Top Sportsman. Very good piece and reasonably priced too. I got his number in the trailer will post it tommorrow.
Chip |
