Old 07-15-2010, 12:10 PM   #1
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Red face motor mount question
are the frame mounts on a 6cyl the same as a small block on 69 nova?
Old 07-15-2010, 01:55 PM   #2
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 307 Times in 103 Posts
Default Re: motor mount question
Can't remember exactly but I think they are the same stands with engine mounts on engine being different and same stands on frame.I think 6 & small block were the same and big block stands different.
Mike Taylor 3601
Mike Taylor 3601 is online now   Reply With Quote
Old 07-15-2010, 02:41 PM   #3
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
Greg,
As I remember the frame brackets were different, because of the the way the six sat in the chassis, versus the V-8. I believe the V-8's all used the same frame bracket, Group 0.029.
Lew
Lew Silverman #2070
"The Wagon Master" N/SA
Old 07-15-2010, 02:55 PM   #4
reera
Liked 31 Times in 6 Posts
I had to change out the frame mounts (stands) on my '71 when I went from the 6 banger to a SBC.
Ryan
reera is offline   Reply With Quote
Old 07-15-2010, 03:43 PM   #5
cad
cad's Avatar
Liked 91 Times in 51 Posts
The frame mounts are the same as 1st gen Camaro, but I cant recall L6 frame brackets being the same or not, and parts houses are not listing them separately... My 68 had a straight 6 when got it, but we changed that out in 1987 and I cant remember that far back.
http://www.classicindustries.com/con...&keyword=frame mount
Old 07-15-2010, 05:35 PM   #6
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
usta be the big trick was to use small block frame mounts with a big block (set the engine back a bit) but i cant tell ya as far as the 6 vs 8 frame mounts.
i got a pair of V8 ones if you need 'em....
Old 07-15-2010, 08:24 PM   #7
Grant Eldridge
Grant Eldridge's Avatar
From memory, the frame brackets are different for 6 cyl., small block, and big block. If I am correct, the small and big block mounts differ in the offset side to side ie the big block mounts move the motor slightly to the right for clearance from the factory. You can bolt the big block into the car on small block frame mounts, but may have issues such as header clearance or oil pan depending on what you have. Companies like Elston headers apparently have a Camaro clip setup as an adjustable jig for whichever set you are using and need to know to properly fit their custom headers to your chassis. There might be info on their web site, but in any case the different frame brackets are readily available from Year One and other reproduction suppliers. Hope this helps....
Grant Eldridge is offline   Reply With Quote
Old 07-15-2010, 09:40 PM   #8
Billy Nees
Liked 7,734 Times in 1,739 Posts
Hi Greg, No.
Billy Nees 1188 STK, SS
Old 07-16-2010, 01:10 AM   #9
greg fulk
greg fulk's Avatar
Cool Re: motor mount question
Thanks Billy. Crap! Dad has a broken/gone frame mount on drivers side....need one! I always ran a strap on my car so not to tear-up mount.
Old 07-16-2010, 05:49 AM   #10
Billy Nees
I might have one. I'll try to get a look later and get back to you.
