Old 01-21-2011, 03:44 AM   #1
mginnett
Default Drive Shaft Tunnel Construction
Race car construction question;
in a tube chassis car I read the IHRA drive shaft tunnel cover material requirement as .120 steel (2011 rule book). Cars I have seen have aluminum tunnel covers.
This is a low slung four link / strut front round tube car, the drive shaft passes next to your right leg / hip. Looking for input on this matter.
Thank you
Michael Ginnett
567 IHRA
Anchorage, Alaska
mginnett is offline   Reply With Quote
Old 01-21-2011, 11:28 AM   #2
63corvette
Liked 353 Times in 102 Posts
Default Re: Drive Shaft Tunnel Construction
I think you are looking at the drive shaft loop not the tunnel.
The loop can be mild steel at .120 or chrome molly at a lesser thickness that should also be quoted in the specs. The location is also dictated by the rule book.
The tunnel spec should be the same as the firewall spec.
Hope this helps.
Rick Cates
63corvette is offline   Reply With Quote
Old 01-21-2011, 01:20 PM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 859 Times in 234 Posts
Applied Racing Technology in Florida makes a very nice kit for the driveshaft enclosure.
saves a lot of fab time.
I've never liked sitting next to the driveshaft.
I've been constructing all my and my customers cars with a 1/8" steel tunnel on the drivers side for years,and started using the SFI enclosure recently.
Saw a guy loose an arm a few years back on a brand new car when the shaft broke when coming out of the water!
made me think a whole lot about the flimsy loops that NHRA required .
Old 01-21-2011, 06:32 PM   #4
Dave Steltz
Dave Steltz's Avatar
Tom , when you say "drivers side", its a half side of the tunnel ?? I've been known to have a driveshaft chase me around the car (in my old camaro, it almost went out the back window)...so with an aluminum tunnel already in there, could this be an added piece, from underneath ? Do you bend it to match the contour of the tunnel...questions, questions...post a pic if you have one....
I thought I read somewhere that this is gonna be a rule soon , or is one already for some cars...
Dave Steltz 135G SG/SP/SST
BIAECH Racing Team
Dave Steltz is offline   Reply With Quote
Old 01-21-2011, 07:20 PM   #5
Tom Goldman
Dave , My roadster has the rear part of the tunnel over the driveshaft made out of .125" CM plate and it covers 180 degrees on the top. ..It takes the place of the tin.
I had S&W bend it to my specs as my bender won't handle that heavy a gauge steel.
I tabbed the frame rails and the "x" bar to attach it to.
Previously I had only been doing the top and drivers side in 1/8" ,but have since changed.
If you have the room ,or are starting with a clean sheet of paper,the SFI tube is the way to go.
I've been lucky and have never broken a yoke or joint, but I've repaired a few cars that had failures,and I can tell you the drivers were lucky to have escaped injury.
The cars had devastating damage to the frames ,tin and sometimes even the bodies!
Old 01-21-2011, 09:49 PM   #6
mginnett
Thank you very much for the commentary, most appreciated. I think I may end up with a .120 steel tunnel, with 2 each 1" x .065 x 180 degree loops over the outsides well as the passage through the main rollcage hoop.
With the 360 degree setups I have seen, how much of a pain in the arse is it to pull the drive shaft / change the transmission?
This is a 66 Nova super gas style car, eventually will end up running mid to low eights.
Old 01-23-2011, 12:03 PM   #7
Tom Goldman
The A.R.T. loop kit really should fit a large car like a Nova easily and the shaft should come out relatively easily.
I will suffer a little difficulty in removing the drive shaft to have the extra protection.
Old 01-24-2011, 12:40 AM   #8
Todd Geisler
Liked 345 Times in 149 Posts
The driveshaft enclosures sold by Bickel, RJ, etc are typically .050" chromoly sheet. It's a really good idea and I'm thinking of adding one to my stock suspension car that I"m rebuilding right now.
Todd Geisler is offline   Reply With Quote
Old 01-24-2011, 10:19 AM   #9
DIAPERMAN
Liked 21 Times in 6 Posts
I dont know if interested I have built some covers for drive shafts also military applications out of Kevlar let me know if I can help 217-454-5289
DIAPERMAN is offline   Reply With Quote
