Liked 359 Times in 135 Posts
What do you guys prefer to use on BB Chevy head bolts? I know....I know......another stupid Ford guy!
Teflon !!!
From one FORD guy to another. |
Liked 348 Times in 152 Posts
Head bolts - teflon paste.
Head studs - whole 'nuther story
Phil Molski PMR Performance S/C 1623 |
Liked 100 Times in 51 Posts
Permatex 3.
Liked 880 Times in 311 Posts
Teflon seals well,but alters the torque reading. Permatex 300 (aviation)
Adger Smith (Former SS) |
I have used both permatex and teflon paste for the threads in the deck surface. Both work.
If you can afford them I think studs are a much better way to go, as the head bolts tend to corrode where the are inside the water jacket and sometimes they ruin the threaded hole in the block when you remove them.
Bill Baer 3391 SC, 339B SC, QR |
Liked 1,912 Times in 429 Posts
ARP teflon sealant works well on head bolts. I do run studs in anything where the rules allow it, that solves head bolt problems permanently. Changing to studs from bolts will likely have an effect on how round the cylinder bore is with the heads torqued. If the block was bored/honed with torque plates, that does matter.
Alan Roehrich 212A G/S |
Thanks for the reply's.
