Old 03-21-2012, 09:03 AM   #101
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
Default Re: Rambler All-American
dwight, were the bellhousing cast iron or aluminum?
Old 03-21-2012, 09:18 AM   #102
Paul Ceasrine
Liked 10 Times in 10 Posts
According to the classification guide, the SC/Rambler shipping weight is 3058. In comparison, the '65 Chevy II SS with a 327 is 2882 and the '66 Chevy II SS is 2917. Considering that the AMC V8 is approx 60 lbs heavier than the SBC and that AMC used a cast iron T10 to GM's aluminum Muncie, the weights seem reasonable and not "adjusted".
Thanks Dwight,,,,,,,,
Just what I remembered, the 1969 SC/Rambler was classed in E/Stock in 1969.
AMC did exaggerate the weight on their specification brochure.
The NHRA adjusted it to #3058 lbs., which was #102 lbs. less.
Performance Results
Car Craft (April 1969)
14.30 @ 99.00 MPH
Car and Driver (May 1969)
14.70 @ 96.30 MPH
Note: Press Test Car, with 3.54 Gears.
Road Test Magazine (June 1969)
14.14 @ 100.44 MPH
Car Life (June 1969)
14.20 @ 98.50 MPH
Speed and Supercar (1969)
13.56 @ 105.39 MPH
Note: Car equipped with 3.91 Gears, Doug Headers, Dual-point Distributor and 7" M & H Slicks.
Super Stock & Drag Illustrated (May 1969)
14.31 @ 98.86 MPH
Note: Press Test Car, with 3.54 Gears)
Old 03-23-2012, 11:44 AM   #103
Paul Ceasrine
Ed,
The rest of the listed items;
* Color keyed exterior side-view mirrors
* Blacked-out grille
* Black tail-light lenses
* Hood pins
* Hurst SC/Rambler emblems (front fender, trunk deck-lid, glove box)
* 16:1 Quick-ratio manual steering
* Power assisted Bendix brakes
* Front disc-brakes 11.2"
* Dealer Invoice,,,,,,, $2732.95
* MSRP,,,,,,,,,,,,,,,,,,, $2998.00
* List Price,,,,,,,,,,,,,,, $3665.00
Old 03-23-2012, 04:00 PM   #104
Dwight Southerland
Dwight Southerland's Avatar
Liked 784 Times in 196 Posts
Aluminum
Dwight Southerland is online now   Reply With Quote
Old 03-23-2012, 07:05 PM   #105
Paul Ceasrine
* Cast pistons
* Forged connecting-rods w/larger 2.25" journals
* Forged crankshaft
* Special cooling features (Heavy-Duty Radiator)
* Power-Flex Fan
* Fan shroud
* Performance Camshaft (.425 Lift / 265* Duration)
* Hydraulic lifters
* Non-adjustable rocker arms
* Delco-Remy Distributor
* 10 1/2" Clutch-Disc
Old 03-24-2012, 09:46 AM   #106
Paul Ceasrine
Car Craft, April 1969
A Hurst prepped SC/Rambler ran a 12.92 @ 107.86 MPH
Modifications:
* GoodYear 8.00 x 14" Slicks
* Crane 302H Camshaft (.477 Lift / 302* Duration)
* Crane valve train components (Springs, Retainers and Lifters)
* Competition valve job (3-angle valve job, milled surface and CC'd chambers)
* Edelbrock aluminum dual-plane high-riser intake manifold
* Holley 735 CFM vacuum-secondary carburetor
* Distributor (re-curved and vacuum advance removed)
* Champion N-12Y Spark Plugs
* Doug Headers
* 3.54 Gears
Old 04-03-2012, 12:19 PM   #107
Jeff Lee
Jeff Lee's Avatar
I took the average of the 5 road tests you previously posted (omitted the modified test cat with headers, etc.). The average was 14.33 ET. That sounds about right for the day.
I then averaged the MPH's, came out to 98.62.
For fun, I used the formula 1320/MPH = optimum ET. That of course is mainly used on a properly prepared car with tuned traction / suspension / clutch and driver. Obviously these test cars do not fit the bill but this demonstrates what we could do with todays slicks, clutches & suspensions and a fast shifting transmission.
1320 / 98.62 = 13.38 ET! That's a whole second faster "than the day"!
Now with the bolt on parts (cam, headers, intake, carb & slicks; "week #2" modifications), the 12.92 ET @ 107.86 equates to 1320 / 107.86 = 12.24 ET!
So if we could go back in time, we could buy a SC/Rambler for around $3,000 - $3,200 and drop another $500-$600 into it for bolt-ons and run very low 12's. Maybe even hit a high 11 with great air and 4.44 rear gears.
Day #1 (stock) = 14.30's. Day #14 (bot-ons) = 12.20's. Day #21 (gears) = 11.90's.
Not bad!
Jeff Lee 7494 D/S '70 AMX
Old 04-03-2012, 03:53 PM   #108
Paul Ceasrine
Jeff,
I'll take one....
Readiing back, many articles stated that the conservative Rambler Dealers did not want this 'wild looking car' on the dealer lot, let
alone in the showroom.
I guess that is why Paint Scheme B was put in place, a little more
subtle look.
Old 04-04-2012, 11:02 PM   #109
Jeff Lee
Jeff Lee's Avatar
I've never liked the SC paint schemes. But the car is pretty bitchin'!
Ken Kier built one a few years ago for a customer to run SS/H that was all white. With that scoop & big slicks sittin' low, it made an awesome looking car. A big name Heni engine builder supposedly built the 390 and it reportedly made 535 HP. That would have made a great chassis a real turd if the numbers are real. And he probably charged the guy some serious coin. It's been passed around a few times, never even going down the track, at least not publicly known. Sure wish I could own it!
Old 04-09-2012, 02:35 PM   #110
Hemi Moose
Liked 12 Times in 12 Posts
