Old 05-06-2012, 01:24 AM   #1
TinSoldier 3215
Liked 6 Times in 5 Posts
Default engine help?
went racing last night and car run fine until 3rd rd. got in car fired it up and it sounded bad and idle hi with out touching the gas. turned it off and toke off valve cover and with some of the push rods you could move them up and down. rejusted valves and still got loose. thanks.
TinSoldier 3215 is offline   Reply With Quote
Old 05-06-2012, 06:48 AM   #2
m147
Default Re: engine help?
sounds like a lobe on the cam or lifter went.
m147 is offline   Reply With Quote
Old 05-06-2012, 09:24 AM   #3
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
Drain oil and look for Stuff in the oil, sounds like wipped lobes. If junk in oil take apart the whole engine, everything will have to be gone over, make sure you get the block cleaned out, cam stuff will be deep in oil galleys.
Bob Pagano A/SA
Old 05-06-2012, 09:57 AM   #4
TinSoldier 3215
If it is lobes on cam what could have cause that?? Or lifters go bad?? Motor haves 155 passes on it. Thanks.
Old 05-06-2012, 10:13 AM   #5
m147
could be wrong spring pressure or the type of oil you are using.
Old 05-06-2012, 10:19 AM   #6
m147
i should ask you what type of cam you running solid hydr or roller
Old 05-06-2012, 12:54 PM   #7
TinSoldier 3215
solid hydr, 5/20 oil rp.
Old 05-06-2012, 10:42 PM   #8
henrys57wagon
henrys57wagon's Avatar
Just throwing this out, how are the rocker studs held in, screwed or pinned?
old 1608 stock racer
henrys57wagon is offline   Reply With Quote
Old 05-06-2012, 11:02 PM   #9
Liked 1,880 Times in 422 Posts
It would really help to know what engine we're dealing with. And some details about the camshaft, and the rest of the valvetrain.
Old 05-07-2012, 12:28 AM   #10
Phillip marvetz
Phillip marvetz's Avatar
Why would the cam going flat cause a high idle?
2009 V/SA Record Holder
