#11 |
I may be doing something wrong. After some tuning my LT1 likes C11. Never one issue with fuel check. I don't drain or seal anything. Your results may vary. LOL
Ed Wright 4156 SS/JA |
#12 |
Liked 524 Times in 141 Posts
Ed,
You are not doing anything wrong. I think C11 is easier to tune than C12 in our stuff. They both seem to be about as fast, but I prefer C11. Pedigo, Quit posting and get back to putting your engine together! Either you show up and race or you get to be my pit bitc... ![]() |
#13 |
Liked 30 Times in 17 Posts
[QUOTE=KRatcliff;325281]Ed,
You are not doing anything wrong. How can you be racing and not doing ANYTHING wrong.... KYLE? |
#14 |
True!
#15 | |
I know race fuel is difficult in Canada at the moment , so this would be an ideal time to make a move . |
#16 |
Liked 1,821 Times in 413 Posts
Amen.
Alan Roehrich 212A G/S |
#17 |
Does this mean that the more a person does wrong, the better racer thay are ???
wow ! I'm the best I'm the best the best, I tell you Just checked, Mike. There's a dealer in Calgary. The fuel seems to be VERY VERY 2 stroke oriented though ? Altidude must make quite a difference. Didn't even think of it before. I tuned carefully, with some pretty high tech equipment on a dyno, here at 3000+ ft, whispy air, using C11. Went to Mission, at near sea level ( 700 ft cool air I believe ). When I got there, I bumped all 8 jets up 2 steps, and bought C12 fuel that ended up getting mixed with about half a gallon of C11 that was in the tank. Car went almost 5 MPH faster than it ever went before. Whatever I did... I want to try and repeat it. I know that may be over simplifying things, but I don't have a data logger, ect, to verify my tune at the track, and I can't really afford to make a half dozen tuning-passes ( car is somewhat hard on parts ).
Aubrey N Bruneau 6409 C/S 62 BelAir sport coupe, 409 HP 409 Last edited by Aubrey N Bruneau; 05-08-2012 at 12:40 AM. |
#18 | |
#19 |
Btw, I do not want to sound like I was disputing what Alan said. I have had too many friends experiencing the fuel check issues with C12 he mentioned. I would never use it myself.
#20 |
I attended a fuel seminar at Sema about 10 yeas ago... the guy was the NASCAR liaison from Unical, and offered up some real good advice (for us non-chemist-types) on race fuels in general. I've also learned a lot from my own experience with dynoing my own engines, talking with engine builders about various compression ratios and cranking compressions. I also have a fair amount of experience with VP's C12, and a little with C14 and C14+. My current engine is built around VP's C12, the mandated spec fuel for this other class I run (outside of NHRA SS).
-Quality gasoline contains the same number of BTUs per gallon regardless of octane. Higher octane does not mean more power (a common misconception) -Octane is a measure of burn rate, or the way I view it, burn retardant. All things being equal, the higher the octane number, the slower the burn. -Higher dynamic compression speeds up burn rate. A high compression engine with a cam that has lots of duration my have a lower dynamic compression ratio than you think. Cranking compression, measured with a traditional (quality) compression tester, is a decent way to determine dynamic compression on a normally aspirated engine. -The simple way I look at octane; the best octane for my engine is the lowest that doesn't allow it to it knock. -Too high an octane will make it lazy, and not want to rev up -use sealed containers, drain your fuel after a race weekend... The chemicals that increase octane by retarding burn rate, are the lightest in the mix. They tend to 'boil off' at room temperature, lowering it's octane rating. -UV light also has a negative effect on race gasoline. Those opaque poly fuel jugs allow UV to get through, I've been advised to use the colored ones that block UV, and store them out of direct sunlight. Also, poly jugs are not a perfect seal, the lighter chemicals will seep through poly jug material, when heated pressurize the cap and make it leak, and the vapor escape when you open the cap. -The 2-valve wedge head engines I play with will not run on VPC12 with 300psi on cranking compression without rattling, but when brought back to 250psi, they will run on C12. Realize that's only one data point for one type of engine, but it may be an indicator of octane required for 250psi cranking compression. |
